Hey all,
Posting on behalf of a mate.
He has a 33 GTST and has the following mods (track only car)
1000cc injectors
Power Fc
Profec 2 boost controller
Walbro E85 pump
Cam gears and cams
z32
Stripped the car completly.
Runs slicks on the rear
Looking at what turbo and what top mount manifold to use?
Plus what forward facing to use?
Will a bigger throttle body be needed?
What he is setting it up for is 1/8th mile dragging.
Hes after a turbo for excellent response and mid range power.
The engine will be rebuilt if / when it goes bang.
Not chasing any specific power goal, just decent times over the 1/8th mile
What options are there?
Only needs to pull hard from a standing start to the end of an 8th mile!
Any other mods needed to?
https://www.sau.com.au/forums/topic/425145-rb-25-turbo-choices/
most cars on the strip are built for bigger power and even plenty of these street cars are the same and have much bigger setups. In yous instance you are talking 1/8th so the question has to be asked is why?
whats the point of the 1/8th? where you heading with the build?
whats quick on 1/8th is going to be usless (or just about) on 1/4
to be honest because the only venue i have to drive my car is an 1/8 mile track.
plus the car will be used for the occasional hill climb and the sorts.
So its more about response and excellent mid range, without running out of puff
Its just hard reading and getting ideas as there is nothing on here for what im looking for.
Its a strickly track only car also, so dont car about a rough idle for cams or a pig to drive etc as its out on the track a handful times a year etc etc
Gtx3071 on e85. Plazmaman plenum with his 72mm throttle body. Should be good for 350rwkw with killer response. Nitrous is awesome set up correctly. Unsure why people dislike the idea of using it. What's a nitrous kit worth now days?
I don't personally have that setup but micko on here did and from all reports pulled like a freight train all the way through. Maybe someone that actually know micko and went in it can explain more? Um I think he made 335rwkw on e85 internal gate version .82! Also on the stock mani aswell.
Lol @ top end, its an 1/8 mile you wont get half way though third gear,
just get a hiflow..stock plenum and everything...it will be just as quick for what you need...
the money you save put towards your suspension setup, tyres and practice runs because that's what will make you fast...
Anyway I know nobody will take any notice of this post so potato...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
