1993 R33 Skyline GTS
I Need Help When Im Doing 100kph my speedo reads 85kph What The F*@k do i do to fix it
Someone Please Help me is there a easy fix ( Car had a Manual convertion ) not done by me Previous owner
PLEASE HELP ME Iv Got no idea what to do
ANY HELP WILL BE APPRICIATED
im running 225/40r18 and the tyre placard says to run 245/40r18s but the width of the tyre wouldnt make much of a difference
The height of the tyre, is proportional to the width.
That number 40, means 40% of the width.
IE, a 225/40 has a side wall that is 90mm
A 245/40 has a side wall that is 98mm
Once you start to factor everything in, that's a much smaller rolling distance, and it means for your car speedo saying 100KM/H, your car is going quite noticeably slower.
But I would say, you really need to convert the diff from auto to manual so that it'll all read correctly again, this would be the easiest and best way to fix your problem as well as changing tyres to the correct size.
The profile is actually a percentage if half the width.
So your 225/40 would be half of 225 and then 40% of 112.5 which is 45mm- 90mm sounded a little high for a 225/40!
Sorry but you are wrong. I can provide links to various tyre manufactures websites to verify that it is the percentage of the full width if the tyre if you like. you have to remember that the sidewall starts at the bead of the tyre. 45mm is small. For me it's the width of 2 thumbs, and given that the rim covers about 1 thumb width, I know that the tyres on my skyline were more than a thumb width from the rim
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
