Hypergear billet T67
highmount mani (NZ one or better)
External gate w/ screamer
Bosch 1000cc injectors
Adaptronic ECU from hypergear
Brass button clutch
4" exhaust
GTR FMIC or better
Tune on E85
Mickey Thompson ET Streets
Slick driving with little to no mechanical sympathy.
https://www.sau.com.au/forums/topic/425210-10-second-rb25/#findComment-6850213
Strip as much weight as possible. and loss 20kgs.
Do all the necesensary engine mods
Run our Billet T04Z with proper manifold and 60mm gate to about 500rwkws
Cutch
re-enforce drift shaft and stronger diff
With bit of luck that the stock gear box won't blow to piece Or put a dog box auto in there.
get adaptronic or some thing similar to setup launch control.
Cross ply M/T wheels and rims
Learn how to drive
By Then you can probably on a flat 10s
  • Like 1
https://www.sau.com.au/forums/topic/425210-10-second-rb25/#findComment-6850237
Cutch
Learn how to drive
so roughly
3k ish for turbo,gate and ecu if all bought from you...?
1.5k for manifolds and bigger TB ....probably second hand...
1.5k for fuel system, 2000 cc injectors pump, surge tank rail and reg..
1.5 for big Clutch
1.5k for tuning and bits and pieces
I'm up to 9k still need a diff /tailshaft or tyres...but budget is looking like it could be acheivable
blow and hookers aren't looking good but pretty sure all the girls will get wet when I win this race anyway :D...
guys this is a piss take.
you could of had a 10second car man...instead you bought a clubsport :P
https://www.sau.com.au/forums/topic/425210-10-second-rb25/#findComment-6850495
so roughly
1.5 for big Clutch
i dont need to run tens.
the only 10 i need is in my pants.
https://www.sau.com.au/forums/topic/425210-10-second-rb25/#findComment-6850514
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
