After putting some new toe arms in and getting the rear toe finally evened out I was thinking.
Firstly, what's the relationship between toe and camber?
As in, if I increase the amount of neg camber in the rear, I'm assuming it will add a touch more toe in or is that backwards?
That said, which would you do first? camber or toe knowing they affect each other.
Further to this.
Currently my car has the following setup.
Front:
-2.5 camber
about 1mm toe in on the pass side which I will be fixing - 0 on the driver side.
Castor unsure, assume around 5 or so deg, whatever the factory arms can give. Haven't looked or measured.
Rear:
About -1 deg camber
1mm toe in (that's on each side so total 2mm toe in). I set this under the assumption some rear toe in is good for grip and stability.
I was thinking I might add some rear camber and possible some at the front if also, maybe 3deg? Tyre wear hasn't been too bad on the current settings, I'm just going through the process of evening everything out.
I realise handling is a personal choice but is there a generic setup that's good for S13s?
I've got stock sway bars and BC BR coilovers F8kg/R6kg)
So also see a lot of people put a touch of toe out up front, say 1mm each side?
What are your thoughts?
https://www.sau.com.au/forums/topic/425556-diy-alignment-questions/
  • Replies 41
try -3deg front camber
would benefit from adjustable castor rod with rose joints at 7 deg
0 rear camber
gtr or thicker rear swaybar
generally you want to remove any slop( rubber bushes) in the alignment settings
front toe seems to be a drivers preference, i've always found too much either way and the car will be understeery.
Edited by Dan_J
depending on your tyre size and how grippy your front is. if your front is a bit understeery then i wouldn't recommend 0 camber but -3 deg of rear camber is no real use for grip
am currently running this for my slip set up with 15's on the ceffy
-3 front camber
8+ castor
rear 0 camber
0 toe
havent tested toe on cornering but car is more grippy with 0 toe on take off
Edited by Dan_J
rear wheel camber is often used on FWDs to help stabilise/grip the rear in corner. Not sure what AWDs make of rear camber, but RWD rear wheel camber is only for the coolest kids who win badges at stance meets. Or drift and win badges for best photo taken of a drifting car.
tl;dr: do you see RWD race cars with camber in the rear? nope.
Hmm, OK I'm happy to hear thoughts, I've just always been under the impression that "some" rear neg camber was a good thing in a grip setup.
I got my original settings from DMS and he seems to know his stuff. (http://www.dmshocks.com/)
A quick example, this grip based S13 -2 rear camber.
http://www.nissansilvia.com/forums/index.php?showtopic=522196
Edited by ActionDan
If you get much seat time, have a play around then and see what suits you.
I re-read where I got it from (people I know, and their merit is obviously of no use on the internet) and the disclaimer is always "what feels best for the driver" and the second thing I noticed was "RWD race teams tend to minimise the amount of rear camber to increase straight-line traction". So I mis-read/mis-remembered and you are right, perhaps some rear neg camber is beneficial. I guess its a balancing act between straight-line traction and traction when exiting a corner maybe?
Pretty dodgy info above. All RWD race cars run some static camber. Even live axles guys will weld/shrink the housing to bend it such that they get some camber on the rear!
You definitely want rear camber for grip work. I had about 2 degrees (might have been a bit over - can't remember exactly) on the back of my 180 on semi slicks. Front you want as much camber as possible. I had about 4.5deg and it wasn't enough.
Less grippy tyres like KU36, RSRs etc need less camber.
Edited by hrd-hr30
I thought as much - no drama though Leeroy, as you said it is personal preference.
I'm running RS-Rs harry so thought -3 might be enough for those.
As for rear camber, -1.5 enough?
Car only has 200rwkw's and it's a CA so that 200 is slower than something that actually makes torque as well.
The best way to find the right camber and toe settings for your car and yourself is through empirical testing, unless you have a tire model that your can use, but you probably don't have the time to do so. Different tires need different geometry, what works with one brand of tires may not work with others (the reason why the tire testing that is done by the magazines can be pretty sus). If the car is to be tracked, then tire temps are a good start, you are typically looking for a even temp across the tread face, with maybe a slight drop from the inside shoulder to the outside, (a peak or drop in the center of the tire indicates under/over inflation) if the inside shoulders are more than 10 degrees higher than the middle, then you have too much camber, if the outside is higher, then you do not have enough. The construction of the tires will also make a difference, a more square (looking along the rolling axis) tire will typically want less camber than a rounded shoulder tire. With toe, a good starting point is 1mm out at the front, and 1mm in at the rear, this will be a fairly neutral setting on most cars. only run toe out at the rear of the car if you want the back of the car to provide more of a turning affect, as it will also reduce the stability of the car in a straight line and under acceleration. if you want to get the car to turn in better, then increase the toe out at the front. My car below, runs 1/0 degree camber F/R, and +1mm/-1mm toe F/R, but it does also run on crossply tires, not radials, F1 teams are currently running 0 or + camber on the rear of the cars due to the construction of the tires used.
1mm total, even on both sides with + being toe out. Toe is a very powerful tuning tool, even more so than camber in a lot of areas and it pays to be accurate with it, you can be 0.5 degrees different side to side with camber and not notice it, but you will notice a discrepancy like that with toe settings.
All done now.
It started out something like this.
Front/Camber/Toe
Driver: -2.5/4mm toe in
Pass: -1.8/5mm toe in
Rear/Camber/Toe
Driver: - 1.3/1mm toe in
Pass: -.7/1mm toe in
And after A LOT of stuffing around it now has the following and "looks" a lot better.
Front/Camber/Toe
Driver: -2.75/1mm toe out
Pass: -2.75/1mm toe out
Rear/Camber/Toe
Pass: -1.3/1mm toe in
Once I drive it I'll know if it suits me or not.
Edited by ActionDan
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
