Hey Guys/Girls
So last week I was checking out the exhaust setup on my R34 and it was just a simple HKS Catback, since I had ordered a turbotech boost controller I decided it would be a good idea to help the car breath better and open up the rest so I went ahead and purchased a KLS stainless steel turbo-cat dump pipe from Ebay. $235 posted. - http://www.ebay.com.au/itm/230881892110?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
There are numerous options ranging from $150 up to 600+ when purchasing this however I liked this one because a) it was reasonably priced for a stainless steel one and b) it had the 2-1 flow from at the top of the flange. I got it installed into my car today (another $200) and I wanted to share so you guys can make informed decisions on your setups.
As the guys at the shop told me the dump pipe normally adds a slight increase in boost response due to the more open flow and bolting directly onto the stock turbo this is a good for those not wanting to run an aftermarket/custom setup. On the drive home I didn't notice any power difference at all, and the sound still remains the same. The guys told me I was losing about 40% flow due to my OEM cat been nearly stuffed so with that in mind I have found a Xforce stainless steel for $195 posted. Will be ordering next paycheque to complete my full system! Hopefully, combining that with my new dump pipe it will see a slight increase, I do feel allot happier running 10psi with a much more open system. I will post results from my new cat when I get my hands on it, hopefully in a week or so....
It should be noted that the dump pipe fits fine but came up just short so the guys had to make a small bend to connect to the cat, otherwise is all ok with the OXY sensor etc. If I get a chance ill throw some pictures up tomorrow.
https://www.sau.com.au/forums/topic/425697-r34-gt-t-dump-pipe-install-feedback/
Be aware that if you do not have programmable management that the boost will possibly rise when you change the cat and the car will probably go into R&R and be slow. You'll probably need to dial back the boost to get it working again.
Nah shouldn't rise when its on a manual boost controller and running 10psi, all I'm doing is freeing it up a bit, not really enough to worry the standard ecu. Its running very nicely as it is
Yeah thats ok, by freeing up the exhausts it'd be lucky to rise close to 1psi if that. Was running 7 with the catback and no MBC. Will post results when I throw the cat in and see how it responds
What are you basing that statement on about the boost rise? I'm going to assume not from experience....... Anyway, you will soon find out.
Mine rose to 12psi when I did the full turbo back exhaust. It definitely rises when you get it all breathing well.
Ran it today on the stock gauge and it was about 13psi so I've brought it back to about 10-11 according to stock gauge. I have a turbo smart gauge I could test with as well but got tired of trying to find a place in the firewall to run a hose through. If I get a tune the only mods I have are the exhaust and MBC so what would the advantage be? And I'm not really up for an expensive aftermarket computer as my next mods down the track will be a front mount and that's probably it (daily driver). Can you tune the stock ECU and do I really need to?
Yeah I have they plug into stock ecu yeah like a piggyback? What does an average tune cost with one of those?
By biggest concern is the tune going bad, car getting idling problems, air cond not working properly or something factory not working because of aftermarket ecu.
Edited by neopowered34
Sounds like my next mod is gonna be a Nistune! What about knock sensor, I was reading a forum before saying that programmable ecu's can cause the knock sensor to fail, are there ANY downsides to putting one in that will affect the little things in my car from operating as per factory spec? And what about my inkectors they are only stock
it's also cheap, $550 with a software licence and instalation, 1k with a tune but nil licence, how much is Link, Power FC, Adaptronic?
There's a guy in Melbourne offering Supply + Fit + Tune for R34 $840!! Too bad I'm in QLD :(
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
