Hey guys, listening to 3AW this morning, VicPol is setting up a trial taskforce in the Dandenong, kardinia and casey(?) area. They said it will be trialled for 3 months. This taskforce is specifically targeting hoon drivers, drag racing, overloading etc. There was also mention it will try and act as a deterrent to hoons who gather and meet up. I had a quick google couldn't find any articles on it yet. Just a heads up!
https://www.sau.com.au/forums/topic/425725-hoon-taskforce-southeast-suburbs/
Well if they are targetting illegal activity that is good! At the end of the day its this stuff that is making it harder and harder to own a modified car!
But if they are targetting like minded car guys/gals and modified cars then that is a negative!
  • Like 2
Lol what a joke. All the pol officers do is walk around bashing people and shoot at them.
That fg meet was a joke, they defected someone for missing a screw in one of the back speakers.
WTF? :O
That is exactly what will happen though. Police breaking up totally HARMLESS gatherings, defects, assaulting members of the public etc etc.
It's only going to get worse.
Tougher you try to behave, the more resistance you are going to get
id like to see the proof of this because the legal litigations that this would cause if you were to take it on would be an interesting matter.
Casey is if i am not mistaken.. the following :
Narre Warren North
Narre Warren South
Gembrook
Dandenong
Cranbourne
Just another way Vic Police is stopping itself from doing real police work. Thieves and Killers can breath easy tonight, knowing that the cops are doing nothing to stop them, but are doing everything they can do stop like minded people getting together to enjoy a similar intererst
Lol proof? I saw the defect notice? Lol by all means it wasn't the only thing he was done for
No, they can defect it, but once you cross the border the defect is useless
So do you guys cop a fine etc with the defect? I assume when returning to VIC the defect will remain and can cause a hassle? I guess this is kind of off topic a bit
i dont believe this to be the case which goes for the same as plates/licence because they have no authority/jurisdiction for it....This is why they push for a change of plates/licence in any given state
This is also the same for truck drivers which is why they have now been moved to an National licence to avoid the issue.
This is also the same for local HWP etc as they can not book/fine/defect outside their jurisdiction of given area/lac
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
