I was only there for 3 months... Didn't really learn much german :/
neither did google translate either it seems. i was there over 3 years. would go back in a heart beat. ive forgotten most of my german now, i use it on the phone every now and again but not as much as id like!
where were you over there mate?
Sheeeeit... at least my ENGLISH is acceptable :P
My mate lives over there... was visiting and also went skiing for a couple of months in Austria
haha, internet english is a shocking language.
Doesn't require too much intelligence when there's guys driving around with I <3 HWY stickers all over their VL's...
Here is something I prepared earlier.
I couldn't help but shake my head for a long, long time...
Here are some of my stats: full license, intact.
Honda Euro-owned 3 years-0 random checks.
Skyline 33-owned 1 yr- 9 "random" checks.
S15-owned 3 months- 4 "random" checks with 2 EPA
mr2 turbo-owned 5 monts- 1 random check
Yamaha r1 motorbike-5 "random" checks.
So basically, if its import, sports car, you will be picked on. Dont let anyone tell you otherwise.
Oh but man...didn't you read the advice? Drive safely without doing anything stupid and you'll be fine (fineD). You obviously didn't drive how you normally drive when you were in the imports.
  • Like 1
^^ don't forget the D. Hwy patrol loves giving you the D
#1 post I have seen from a-a-ron!
dw.... it only took 14,582 to get there
Another update of my experience....
Drove down to local coles to buy milk last night, at like 9:30pm. Drove into the carpark, and at the roundabout, there was a car on my right, so I stopped and gave up, then I saw a cop car behind the first car, so I waited a couple of seconds. The cop just looked at me and stayed stationary.
So I drove through the roundabout knowing that he was waiting for me, drove around the carpark and found a park, got out. He pulled up behind me, wind his window down.... So I said g'day office, he replies with "got your drivers license?". He went through all the checks then let me go.
Are imports targeted or was it random? you be the judge lol
Lol nothing random about that.... Lucky your car is a nice stealth colour :blink:
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
