I took this screenshot from the current tune in my car. After reading some online sources about power fc tuning, I recalled these settings and from what I have read, they should not have been changed. From what I know, these settings are used to alter the AFM calibration if it has been housed in a different sized tube to what it comes with standard. My car is running in the standard afm housing with 3" piping infront and to the turbo. According to what I have read, these settings should not have been changed. When I got this tuned the second time(the current tune), we didn't think to check this tab and it was only weeks after we had noticed it. Now its been a year later and I'm looking to try do some DIY tuning to help increase the fuel economy on my car and just eliminate some knock in the upper end.
If I changed this back to default; 100 all the way down, will it throw out the tune, mainly the injector map? My car is a standard motor with the SS2 turbo and supporting mods with the Z32 AFM.
Thanks all.
Yes it will alter your tune. Your fuel map references the airflow values vs load and that's how it knows how much fuel to throw in.
If u have a wide band setup it's very easy to see how changing those values affects ur tune. Ie ur fuel map may say 14.7 afr reality is that it's 14.2 so u tune the corresponding afm voltage up or down till the fuel map matches reality.
Isn't what you said about altering the afm voltage about altering the air flow curve table? The air flow curve table lets you see the load point then alter the air flow voltage at that point. The part I'm picking on is the top part where you select the AFM you want and the numbers next to it. Everything Ive read said to leave those at default 100 when using the chosen AFM in the standard diameter housing.
it's because some tuners bend the AFM scaling to tune the car rather than set the injection table... not sure if it comes to preference or sheer laziness, I've always had mine all default and adjusted the injection table to suit (back in the days when I did road tuning for myself)
are you having issues with the way the air flow curve goes down the map during a power run ? or cruising?
if everything is working fine then just leave it and fix the issues you have.
or re-set the pfc and start again. i used to play with the air flow curves, but i had a q45 afm and major reversion issues.
Issues are with cruising. My wideband shows a pretty rich mix 12 to 13 cruising.. If I did want to start again would I be safe to use the current ignition table? Really have no problem with power its just the way it skulls down fuel and I am a pretty calm low rpm driver. Haven't had a chance to do any logging yet to see what's going on with air flow curves and load.
It wouldn't be hard to drop the voltage but I think its more thsn just dropping it. I'd suspect it has to be scaled to 0 to 1v. Ive got a bung at home and should have my o2 sensor which is almost brand new so I'll try get it mated up. If fuel eco doesn't change much ill try do some leaning to the cruise charts. Ill upload a screenshot of the table ive worked on so far.
http://www.schnitzracing.com/manuals/AEMWBK.pdf
Page 9 of the manual states that P4 on the rotary switch is 0-1V output. I thought it had narrowband simulation built in... Try it out...
anyways I suggest you turn off O2 feedback on the PowerFC and tune the A/F so it's stoich on cruise and light throttle.. once that's all set up just plug up the stock O2 and see if it still reaches stoich.. if not it's time for a new stock O2
How did you sort reversion issues? My air filters sound like Darth Vadar the way they breath in and out
I haven't loaded this tune yet, I'm going off current actual afr's and looked at another tune I found of a car with similar mods. I didn't make significant changes but what I tried to do was get everything flowing smoothly and evenly.
I'll need to do some more logging see what cells are being hit the most during common, light use and work with those but overall I think if it blends in more evenly and consistantly, it should run smoother and there won't be such drastic changes in afr's when cruising.
well stop looking soo much into it and just adjust the areas of the map that need weaking and lean it off. leave everything else the way it is. why touch something thats not broke ?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
