Hi All.
Once I get back from my Thailand Trip!! Wooo, ill be making some new upgrades.
I'm looking to get a new brake kit that's not 10 grand like most of them.
http://conceptzperformance.com/Cart/description.php?II=3303&Car_Type=G35&UID=20130524002102219.90.244.239
This akebono seems like a better upgrade from just stock brakes. I know it's no brembos but better than stock.
Anyone know of any other places to get them? Or a different option maybe.
Thanks
https://www.sau.com.au/forums/topic/425801-akebono-big-brake-kit/
Hey mate, I am considering upgrading to a V36 in the not-too-distant future, at which time I will probably pull my slotted floating rotors and Brembos off and sell them. How soon are you looking to do it?
FYI that kit you linked to is great, but once you pay for shipping and GST/duties, you will be WELL the wrong side of $3k. They are not too far off 100kg for all that gear believe it or not. Shipping from the USA is a bitch.
Ahh, have you got any specific photos and specs of your kit? link maybe.
Yeah i have looked at the z1 site, 2500 and 200 delivery that includes berk hfcs and a free cap!!!
I just pmd conceptz for a quote.
See how we go.
Ps. Get back from Thailand 17th June...so that soon
Edited by runner4life
My kit is standard Brembos off a manual V35, with Stoptech 2 piece floating rotors http://www.z1motorsports.com/350_g35/product_info.php?products_id=5563
Nah, let me guarantee you that delivery WON'T be $200. Like I said the kit is about 100kg. I paid about $350 to ship mine here a few years back, and postage rates were much cheaper then vs now.
Also, it is illegal for the US business to not declare the correct value, so you will find that for items of this value most will put the invoice amount on the package. Duties and GST on products worth $2,500 will run you around $400 in duties and GST (assuming $200 postage cost is correct, which it is not). Just factor this into your decision.
I will be asking $2k for my kit, and it will come with decent pads too. I probably won't take off my braided lines, but tbh these made NO difference - I wouldn't bother if I was you. If you DID want to bother, braided lines can be had for around $200 delivered out of the USA.
I'll just wait back to hear from the two companies and see how I go!
I'll keep yours in my mind too!
$495 from Conceptz....so that would be $2335.
Not bad for alot of kit....I will see what the z1 site does it for with the berk HFCs too.
I'm not worried about being illegal. Where I drive, all the cops know me ;) Advantage of being "in house"
Is there a disadvantage to the adapter? Why illegal?
I have aftermarket 18s. The site says fits 18s and above...Hopefully is ok, i can print out a template to check.
Whilst I sorta agree, going overboard with brakes and tyres makes more sense than doing so with power mods.
Also, the "Z1 Akebono Big Brake Master Kit" comes up at $1700 delivered for me - although that is with Infinti calipers, Centric rotors and pads and no brake fluid.
Curious as to where have you seen a full kit of V35 Brembo's for $850? :woot:
I just think its a reasonably priced viable option for safer brakes...and you can go through the hills in comfort. Im going to get mine powder coated yellow/gold. Cross drilled and slotted will look sweet.
I have expensive tyres, so makes sense to get better brakes if they can handle it.
Well this will be closer to 2.5K by the time it gets here
Locky if you read what iamhe77 has actually written, for the brake set alone from Z1 it is free shipping. Confirmed by Z1 themselves. So where is the magical $800 extra coming from?
I've done some reading on cross drilled. I'm not going to be driving track, I do that in the cop cars enough. So crossed drilled is "ok" unless your using them in severe applications, street driving....severe? no, unless you want to be stopped by me and have a chat with a friendly officer ;)
Worst case scenario I change rotors if they happen to crack after however many ks? meh
They won't crack.
I ran cross drilled 296mm on a full weight m35 on a light track day. No cracks.
Running really high 800+ degree pads on a race car doing lap after lap? Sure, they will crack. Considering Porsche and orher high performance marques, use cross factory discs, I'm not sure cross drilling has a lot to do with it, rather disc material composition.
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
