Never heard of horror stories with this, so long as its used for its proper purpose.
Not for AFM filament I don't think.
It's so powerfully effective, it's been known to take grime off wheels that nothing else could remove.
It was always used at every service on my Subie Foz XT down the piping. Recommend!
If you read the directions on the can, it stipulates to spray half of the contents into the inlet manifold while the motor is off and to wait 10-15mins before starting so it can do it's thing. Then, when it eventually starts, it will take some cranking to get it going, speed the motor up to 2000-2500rpm and spray the rest of the contents on and off letting the motor breath. The revs will drop as the nozzle on the can is depressed.
Any Success/Horror stories?
Lawwwwllz. Yes.
I was spraying the straw into one of the ports on the plenum and the vacuum sucked the straw right off and right into the runners.
After trying madly to get it out with a grabber tool, I only ended pushing it further in.
I eventually gave up and ran it through the engine.
That was a few years back and I never think it did any damage.
Moral of the story: attach some thin pvc tube or similar to the nozzle. That way you can always keep the can upright, and the straw wont get sucked through the tube.
Good shart, but beware, if you leave it for too lone it will start to eat gaskets and goos. Also, don't use on rb26's per throttle body as it eats the thin film of silicon that seals the butterflies. You have been warned.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
