yesss will be keeping a close eye on that. Thats going to be a very interesting result.
Well we already know what sort of result its run on a crazy Evo, Now itll just run on another crazy Evo :P
It will make around the 480 - 520KW mark on a well prepped Evo at approx 35psi.
But I guess the thing to watch will be the powerband, not really the topend.
Soft!
Probably not a setup most people would go for on RB25s, a HTA3582 will make more than enough for what most people would need in a RWD - so I'd not hold my breath for that one haha. A mate's GTR (RB30/26) is going on the dyno with his HTA3586 tomorrow on E85 so I'll update on how that goes.
So you saying no Super 94 for me next? :( lolz
Cant wait for your results! :yes:
You do nothing but skids so it's EXACTLY what you need!! ;)
Lol sonofabitch! Problem is i cant argue as since the tune it hasnt been used :( lol
And why is that?? I'd have thought you'd have put thousands of kms on it!!
After Texi it ended up with a screw through the tyre... After that our yard turned into a mud pit and i cant get it out of the shed! No real reason, just shitty stuff!
Lol of all the reasons... :)
I hate getting a slow puncture, that ruined my kumhos and forced me to change early.
No mechanical issues thats for sure! Its next appearance will be the SAU Putty Rd cruise! Will do some suspension work before then but other than that it should be sweet!
Ran into electrical gremlins on the dyno - it's a freshly built race car, and it was a bit of a rush to get it on the dyno. It made 500awkw (rolling road) on 24psi running E85 with more in it, but I doubt that will happen too soon.... I'll naturally update when anything else happens :)
Shame about the Gremlins but..... :woot: :woot: :woot:
Was this with a 1.03 exhaust housing ? Do you think it will make 600kw with more boost ?
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
