This is true. But shit does sometimes happen. Fingers crossed it doesnt lol.
Yeah i know how easily plumbing can add up, especially when it runs the length of the car a couple of times over.
Ive never personally driven PI, but i can see where you are coming from. I was more thinking about the front and rear distribution, rather than left and right. But I dare say you'd have more experience in this than me haha.
Good luck man. Would love to see this thing screaming in the metal.
Lol, If we stack the car the oil tank will be the least of my worries dude. I was advised that weight in the rear isn't the ideal place. I'm sure everyone has there own ways of doing it though for what ever reason.
FWIW Mark Berry's R32 has the oil tank in the front also. Doesn't seem to slow him up any... :whistling:
  • Like 1
would like to see that wiring loom, is it getting simplified?
Will be very simple as most of the electrics are gone. Ill post it up once I know what has been made shortly.
What I've been told for now is..
Ecu to engine loom
-cylinders
-coils
-throttle position sensor
-mat sensor
-ect temp
-map sensor
-crank angle sensor
-cam angle sensor
-oil pressure
Body loom
-rear lights
-engine switch
-starting circuit
-ecu power
-shift cut module
-diff controller
Motec data loom
-g sensor
-speed input
I'm sure I may have missed some but I think that's about right, will know when Gary Rowe finishes the loom.
Edited by stevena
Thanks James, will head over to see yours if you let me in your garage, little progress update...
Borrowed a set of wheels as a second set for testing and wtac, we ordered two sets of hankooks z221's in 295's/30, one is hard compound and one soft set for testing. This is what the fit up like on a 18x10 rim, our te37 are 18x10.5 so will fit perfect.post-19978-0-32985600-1377156505_thumb.jpgpost-19978-0-51952200-1377156585_thumb.jpg
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
