  • 1 month later...
hey guys,been busy in the last months and havent had any time or new things to update about haha.but now i do
Changes & problems.
-The fuel pump gave up on me while on the fwy (cost me $400 that day)had to change to walbro 255 not as good as the 040 i reckon
-Car had a problem it kept shutting off while i was turning or reversing while turning.But cleaned icv and the problem is gone now.
Updates
-I finally got FMIC installed today & its great car goes hard in 2gear(11psi).The manual boost tee needs replacing tho.
-got rims :D Rota grids are on(Blue) 18x9.5 +20 offset.Sticks out a little but its alright for now since gaurds are not rolled yet.if you don't like them don't comment.
-Since i upgraded some things,the way the car handled needed some attention now i got both front and rear strut brace (hicas will go on on friday) car handles alot better than before.Future parts im ordering soon to complete the list are AntiRoll Bar(front/back), camber & coil overs and more just to make the car better.
Future mods
i'll probably start saving up for power fc,splitfire coil packs and upgrade to a EBC
Looks wise
-I like the way it look atm,but maybe i'll change to a carbon drfit style spoiler in the future.
here are some pictures.
Feel free to comment and suggest bits.
post-112075-0-60811700-1381585554_thumb.jpgpost-112075-0-35273100-1381585548_thumb.jpgpost-112075-0-55799200-1381585541_thumb.jpg
Looks awesome landyy
I got very similar spec rims but mine are +22
They did require a roll of the guards though.
Check to make sure it's not hitting anything under the guards, mine was hitting a wiring loom which wasn't tucked up enough.
Love the rims :)
  • 2 months later...
Time for a update.
Intercooler was installed & car is currently running 11 psi.
Since last time,car has now Tein edfc coilovers & i changed to rota fighters(specs 18x9.5 +20 offset) i like these rims as they make the car look really mint..
Car now has front and rear strut brace & hicas removed.
i decided to sticker bomb my fuel cap and added a few stickers.(not over kill or random ones).
*Car now has Led tail lights,i like the look and i'll keep them.All lights have been replaced n got Hid's.
here is the link for the Hid's,very easy to install and i would recommend them for anyone chasing some.
http://www.ebay.com.au/itm/35W-AC-H1-HID-XENON-Kit-Nissan-Skyline-R32-R33-R34-S14a-S15-200sx-6000k-8000k-/161051422456?pt=AU_Car_Parts_Accessories&hash=item257f69aef8&_uhb=1
Future mods
-2 weeks time from now Os Giken single plate clutch + flywheel and 2way diff going in :)
things to be done.
-Private plates(ECR33,MYY33,JDM33,SW33TRB) Do give me some ideas for plates or wat you reckon sounds good!
-Ordering a highflowed turbo or might change my mind go top mount.
-660 jecs injectors
-ECU(nistune or power fc)
-3" intake pipe
-whiteline anti roll bar for both front and rear.
-Camber kit(maybe)
-aftermarket bucket seats.
-nismo clear indicators
-toyo r88.tyre i have on atm are achilles atr sport they are ok,but once i get more power i'll change them
might have missed some things.
Here are some pictures of what the car looks like atm.
enjoy and please do comment
  • 5 months later...
THE SEARCH FOR HP-Silver bullet slow start.
It's been a while since I've updated this..but the search for power never stopped.Car is almost done & I'm hoping she can push out close or pass 300kw.The body looks the same,only changes are a new set of rims as I got over running copy rims (rotas).Enkei rpf1 18x9.5 + 15 all round wrapped in star fire RSR(excellent all round tyres tbh & i would recommand them to anyone).I've gone with a low mount set up with external gate & the turbo is the latest hyper gear with a op6 rear housing.Top mount here is a 100% yellow sticker so kinda playing safe & not wanting to get done by the donut eaters.This is just the mods I've got & I'll post actual vid n dyno results once car is done.
-Greddy Ebc
-Hyper gear turbo
-Utra gate
-Steam pipe mani
-Os giken single plate clutch
-660cc jecs
-Z32
-255(might upgrade)
-Greddy fpr
-Split fire coils
3" to a hks dragger exhaust(bigasf)
& a nistune.Thinking of getting rid of it & getting a PFC though.Few things I'll do such as brake upgrade,2way dif & anti roll bars along the way
I've learnt to do all work by myself with the help of my brother so yeah it takes time,but we'll get there..
Worst of the worst has happened to me. 2/12 studs snapped, managed to get one out using drill & easy out.The second was pure bad luck, the stud snapped & once drilled, inserted the easy out, the easy out snapped into the snapped stud.My brother went to drill it out and since the easy out is a hardened he pushed too hard & drilled into the head(5mm-10mm).Worst nightmare. car is sitting in the garage untouched since Saturday. I believe he has drilled into the oil barrel. My question is amI f**ked & will need a new head,will that affect my tune/car in the future or would the new studs block off the hole?.The drill bit was 3.5mm I believe. Smelled of oil n thats all I could see when we took out the drill bit. Any input will be helpful especially someone who has done this before. I've done heaps on my car from coilivers to clutch with my brother & everything between, by far this is the biggest f*k up haha.I'm depressed now lol.thanks in advance.
That sucks man. Easy outs are very hit and miss and need to be used with care as you now know.
For future reference there are mobile thread repair businesses that are experienced and have all of the right tools to do the job easily (they typically don't use easy outs)
Depending on what has actually been drilled it is posible to repair it. Either by welding or tapping larger for a plug.
Best thing would be to remove the head be assess from there.
Edited by Ben C34
Good news the bolt is off. My brother had the same setup as me with one of the hybrid manifolds, the manifold cracked the night before the tune(tiny run)still took the car in for a tune and tuner couldn't get tuned as it spiked so much at 5,000rpm(38mm ultra gate).Soluton was get a bigger wastegate and with w as wastgate pipe.So I'll be going top mount instead. Hybrid is a f**k around and the seller kept arguing when we messaged him about the manifold. DON'T EVER BUY A HYRBID MANIFOLD. THE WELDS ARE SHYT AS.
OH WELL I LEARNED.
Edited by Landyy
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
