Well the set up is complete
booked for 5/12/14 Mick at Ovaboost will be tuning the car.Have gone with totally different parts from what I originally planned.Sold most things i had.As of now these are the mods
-gt3082 1.06 rear
-high mount steam mani
-50mm pro gate
-750cc bosch injectors
-Aftermarket front facing plenum
-bosch fpr
-Splitfires
-bigger throttle
-Haltech platinum pro
-pro flow fittings all around
-plus more
I'll post up photo of engine bay when im on comp.im expecting big power and the haltech is able to do alot of great things
Yes and it has alot of features too, boost can be controlled by the ecu using a mac, launch control & no need for afm . Engine bay looks really mint. One thing I've learnt Is that buy parts that you're going to use 110% well most things always don't go your way:/.
Here are photos. I went with blue. Tuner will do welding & other fabrication needed.
Edited by Landyy
  • 1 month later...
  • 3 weeks later...
  • 8 years later...
wow crazy how time flew by and life got busy.Qualified in my field of work, travelled the world ( including jdm land) & matured up etc. I was just 19 when i bought my 33, reading back i can see how excited i was! now 28 still excited but rational! kept the 33 till 2020,plenty of events attended and i enjoyed that car, met and made alot of friends, been to world time attack, gtr festival,racewars,tokyo autosalon, snowy mountains 1,000 & plenty of other events. Bought a 32 gtr back in 2016 that car ended up making 600whp on e85 did powercruise and was a solid street car, ultmately threw a rod (typical rb26 stuff). Sold the 33 to finish off my 32 gtr build, Nitto 3.2 stoker kit cnc ported head, samsonas rs90, precision 7675, emtron ecu,mechanical fuel pump aiming for 1200+8sec. Gtr build isnt far off  being done. Cant thank everyone enough for the replies, the little knowledge helped me alot to venture into other things. Now i can pull out an engine, pull it apart and put it all back into a car etc. I'll do a final post for the R33 with photos before i sold it. If you would like to follow the gtr build its on insta under 90s_hero_32. The car scene has changed alot, everyone is car enthusiast apparently & you must respect them even with a junk build filled replicas, china spooly boy. SAU keeps the egos down compared to other socials.
  • Like 2
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
