What Is 'too Much' Power For The Street?
74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
no 500kw car is going to be convenient or street friendly on a daily basis..and the price of fuel and wear and tear will soon have you buying a barina to get to work in....
doesnt mean it cant be done though, but even a 300kw car isnt always great on a daily basis...there are far more comfortable ways to get around...
Would I not drive on a street a 458, GT2, Veyron, Koeniggseg, Aventador? How much power do they have? Why would I not then drive a big HP GTR on a street just because my budget is lower?
Now what street are we talking about?
Now Mr Willis's private 'street' up on the Central Coast looks the goods.
According to JEM's latest Lambo tests they come from factory with bugger all..... Twin turbos should soon rectify that!
300 odd rwkw is getting closer to 'enough' for the street.
Would not go any bigger on a cam than what I have for a manual and regular street driving, too much overlap = a prick to drive smoothly through lower gears. Stalled auto = no problems.
I'd say the upper limit would be where you can't start opening it up without losing traction - tyre choice, suspension of course play a big part in it.
Same with big turboed imports - my old R32 was laggy and it sucked balls unless wringing its neck. 4.3:1 diffs did help with that though.
All depends on the car.. A 400rwkw Silvia is alot more silly than a 400awkw GTR.
Perfect daily street car would be a mild low 300kw GTR (-7s or -9s). Standard looking engine bay, relatively reliable, mid - high 11s quater mile on street tyres and not all that expensive to build. Once you wind up the power things tend to go bang..
In saying that low 300's does get boring :rofl:
Sif high 11s with them mods, i did that time on stock turbos and stock ecu ! 234kw
I hope to run a high 10 with that setup :yes: :yes: :yes: :yes: :yes: :yes:
Edited by sultanaz
My 26 GTS4 with 280 odd kw is more then enough on the street - to the point were i haven't even touched the high boost setting
Mind you its running RWD at current so i take it half easy - and is the first Forced Induction car i have driven so of course it feels quick to me
The power im getting used to it....
Hard question to answer but id say even 200kw is more then enough
Boost level and power level is still all controlled by the right foot :P
I agree with that for sure and just because a car is 300, 400 or 500kw that does not mean it has to be driven as such
i think better wording then "Too much" is usable
Yep, its the good thing about modern turbo cars :yes: Can be driven daily without knowing its got big power! Mine is smooth as on the street, its only the idle that gives it away now!
I hear you brother! the straight exhaust with single hooker muffler can be quite loud haha
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
