Oh no... Did you parked it on a hills? Automatic cars are not able to be parked on hills without causing permanent damage to the entire drive train.
I'm sorry to tell you this, but it will cost approx $3600 to fix your issue.
Your local mechanic needs to be told that your parking selector gear cog is bent from parking on a hill, and he'll know what to do to fix it for you.
https://www.sau.com.au/forums/topic/426439-gear-problem/#findComment-6878689
Thats his problem Aaron, he wants the D but he's stuck in the P and the box has given up waiting for him to make up his mind which way he wants to go with his life...
Bro just get the bus, it'll be easier for you in the long run.
https://www.sau.com.au/forums/topic/426439-gear-problem/#findComment-6879063
Well obviously the P isnt working out too well for him so its time for him to start getting out the grinder and getting the D.
As brat said. He blew it. The transmission fluid might be a bit cloudy.
This is gross
https://www.sau.com.au/forums/topic/426439-gear-problem/#findComment-6879071
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
