Gday Fellas,
Im relatively new to the forums. I have always been a lurker. Sitting in the shadows watching other people build things and then hopefully implementing them on my own car.
It all started in early 2012 where i finally decided to bite the bullet and visit Mastercars Blacktown to purchase my very own r34 gtt. I fell in love with the red r34 they had sitting there for the last month and I knew i had to have it.
After a little bit of haggling here and there I ended up buying this:
It was a clean example with a factory sunroof.
The only aftermarket parts were:
18" rozza wheels
blitz turbo timer
hks hiper max d coilovers
Im not really looking to build a track car. Just something clean and streetable that packs a punch. let the modding begin
https://www.sau.com.au/forums/topic/426655-the-red-lady-sandybangs-r34-gtt/
Everything was looking great at this point.
Here is my engine bay:
I got all the fluids (clutch, diff, oil, coolant etc) all drained and replaced.
I soon realised that i needed to get my brakes done.
So i went from this:
To this:
And i always wanted a bit of woosh so i ordered this from nengun:
and just to keep it somewhat legalish i got this from hi octane motorsport:
Now in order to prepare my car for better flow I was on the hunt for a decent exhaust system. I ended up with a nismo turbo back exhaust (including genuine nismo hi flow cat) that i got for a bargain!!! Such a sweet note on the car when you open it up and none of that annoying drone. And it looks kind of stockish.. not really.
And to further improve my flow I purchased and installed a black series kkr intercooler from otomoto. Does not have the same flow as say a blitz or a hpi but i am quite impressed for $400 brand new with piping. And it didnt require much cutting at all
Finished product:
Also changed the parkers to smd leds:
Edited by Therealsandybang
I ended up buying 19" starcorps for some fat fitment. They started off being like this:
To this:
On the car they looked like this:
But i was never really happy with them. It was way too bumpy and the wheels felt heavy. I ended up going back to my trusty rozzas
I also decided to remove my old clutch and get a new custom exedy single plate organic clutch kit from western clutches:
old:
new:
It was a bit heavy for the first 700km but now is quite nice.
Got some new gauges. Not sure if too ricey?
First I went and bought some supplies :
The rb26 bov has a larger pipe so instead of using an adapter I used the original factory pipe inside the new radiator pipe as a collar. I sealed the space between them with gasket sealer.
I was originally going to use a rubber gasket glue to attach the rb26 bov. It appears that the gasket from factory is a much better option if it is in good condition.
There was a bit of dirt And grime on it so I sanded it lightly before:
After:
Here is a comparison. Left is the neo and right is the gtr
Before:
After:
I also replaced the heat shielding stuff.
And after all this I still get the fart noise.
Lol oh well
I've just gotten my drainage sill things painted under the hood and in the boot. You can tell in my previous pod box image that the sills were faded and slightly rusting.
Same story in the boot.
I've got a nice clip on rear camera kit from carbon car systems. It's a factory looking fit.
I also hardwired a dash cam and hid the wires.
This is a pic of my universal washer bottle and pump fitment. I got it in the factory position. Yeah!!
Repainted the rozzas a grey carbon with gold flecks
And some door protectors. I know it's granny spec but it protects my doors lol
There was a cleaner factory option in s2 33s which icouldnt find for a 34
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
