Hi guys I have a t28 high flowed turbo from an s15 on my rb25 I only just bought the car about a month ago it was going fine holding boost at 15 psi until the other day when I booted it in 2nd gear and there was a Big Bang and I blew off a cooler pipe so I put it down to that limped the car home and fixed up the cooler pipe then wen I took it out next the turbo won't make any boost runs fine in vaccume but then wen u boot it the gauge holds at 0psi I first thought I might have a boost leak but now I'm thinking its probably the turbo can anyone confirm this? If so what is a good turbo to put on I have a standard ecu 3 inch exhaust and fmic I'm looking for about the same power maybe a little bit more
https://www.sau.com.au/forums/topic/426740-blown-turbo/
That oil in the front of the housing is normal, its from the oil breather lines. That shaft play is probably not 2mm. I don't think your turbo is a problem, I think you've still got a leak somewhere. If you damaged the wheel or suspected you popped your wheel, you would be here with severe engine problems because that wheel would have been eaten by your engine.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/426740-blown-turbo/#findComment-6884815
Might be a stupid question, but does it still feel like it is making boost, or are you just saying it makes none because the gauge says so? If it still feels like its making boost it could be as simple as the boost vacuum line has come off.
https://www.sau.com.au/forums/topic/426740-blown-turbo/#findComment-6884954
Well it turned out to be a boost leak in the boost gauge line I don't know how the gauge read vaccum it was a massive crack, I went to the local truck supplies shop and bought some new 8th inch plastic hose for 2 bucks and found another small leak now there both fixed the car boosts properly only now I have another problem now at about 5000rpm in first the engine breaks down and splutters and looses power also if I'm cruising along in 5th then ease power on it begins to splutter. The car has splitfire coil packs there probably old so I'm thinking one might be stuffed I have replaced the plugs and it made no difference so I'm hoping it will just be one coil pack, buy a new one and then work out which one is failing well I'm hoping it will be that easy anyway
https://www.sau.com.au/forums/topic/426740-blown-turbo/#findComment-6887586
I live on the nsw north coast just abit to far away lol cheers anyway I have a mate who I can borrow some coils off but he just went back to work at the mines and he won't b back for a month which sucks I don't wanna wait so ill prob just buy one and see if I can fix it that way
https://www.sau.com.au/forums/topic/426740-blown-turbo/#findComment-6887592
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
