Many varied opinions, overall I think the chicks win. Both good cars the 34 is way more practical but I love Supras too. Cops may pick on you more in the Supra as looks to be going too fast even when parked.
Cheers, Grant.
hahah i notice there is never any pics of the interior of the supra! the worst looking interior ive ever seen!!!!!!!!
on a side not what wing is this 34 running?
Stock with different wing stands?
If you have high expectations expecting an interior from a jap import who made the interior cheap and tacky on purpose to keep costs low; you're gonna have a bad time. want a fancy interior and lots of space? get a toyota aristo :) same motor as the supra and just about as quick. Honestly you get a stupid amount of car for the price of them.
Fine... NSFW
http://vimeo.com/
add: 31515908 afterwards if you want boobies.
Man would smash that so hard.
that you know that makes me respect you a lot.
yes, would also smash.
N I personally don't think it was worth a warn. All I could see was black blobs :P
Aristo about as quick as a Supra?
Since when did the Aristo have as much success as the Supra did in JGTC ??? Oh wait it didn't even race in such a series.
And Supra has an amaziiiiiinggg interior, feels like you're in a jet fighter plane. Totally awesome.
thanks for everyone help, I actually went a different way and brought a v35.
"This is a CEFIRO!!!" (Tsuchiya negatively describing the performance of the V35 Skyline)
  • Like 1
I owned an R34 and a Supra at the same time a few years back. The supra was awesome to drive around when it was just me and my wife in the car. If we were taking anyone else, it would have to be the R34. At the end of the day, it all comes down to what you want to use the car for. Yes the stock internals in the Supra can handle more power, but if you are driving the car on the road as a daily, you wouldn't want that kind of power anyway. So, for a car to be good fun to drive that can be modded to decent power for daily use and still be practical, I would go for the R34.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
