yep (to looking factory) with 1x missing 10mm bolt.
You will need to pull out the fuel pump cradle and see what's actually attached, a service lid/hatch photo won't show us much :)
Okay I'll pull it out and get another photo. I'll edit this post.
Thanks for your help so far. I also need to pick up a DMM to check whether the fuel pump voltage trick has been done
edit:
okay This is what was underneath the plate. looks kinda stock to me but I don't know much. The markings make it look like its from a wrecker. Maybe there was an aftermarket one in there at some point in time but not any more?7Nc8pTs.jpg
Edited by Blackkers
OP, we can't tell you anything about the pump without seeing the pump itself. For all we know, the original owner could've locked their kid in the boot and the kid has got his textas out and started doodling on the fuel pump access cover. Can you get a pic of the pump at all?
It's like me showing you a picture of a GTR without the bonnet open and asking if the engine has forged pistons.
huh? loom, what happened to the loom, 1 it looks fine and 2. that wasn't his question?
OP what does it say on the pump!? names, numbers etc
Oh, good grief. When insulation tape has been all unwound off a wiring loom it tends to suggest that someone has been in there doing something. No?
Seriously.
without the sump off u mean
Seriously.
That's doesn't tell us what fuel pump there is tho, for all we know it could still be stock from a wrecker, Op needs to show the pump itself
Alright, I've never removed a fuel pump, does the black plastic cap unwind? Also I'm guessing I should disconnect the battery first.
I'll get another picture up soon thanks for your patience!
no need to disconnect battery, the car won't explode like the movies..
just unplug the lot and mark out the fuel lines to where it goes..
open fuel cap (to relieve pressure)
disconnect the electrical plugs
disconnect fuel lines (they will spray a little bit of fuel)
then open the black thing, by turning it anti clockwise, you may need a piece of wooden and a rubber mallet (there's a special tool for it, but meh)
then remove that black thing
pull the whole assembly out
Then curse the day you pulled the bastard off when the black plastic ring won't thread back on for the next 20mins while bending into the boot inhaling petrol fumes....lol
At least that's how I remember it.
Or if you decide to put a larger pump in there, say a 040, rage even harder because you can't find the groove the thing slides into and when you finally do, the pump hits the bottom too far and you gotta take it out again and adjust. Probably the ugliest job Ive done on my car.
Those texta markings won't be from factory, but at the same time not necessarily from the wreckers but it probably is the most plausible event. Something tells me a child wasn't locked in the boot.
Be warned, you might need a new gasket when putting it back in. A tip I read on here is to throw the old seal into the freezer to prevent it from expanding. If it expands its pretty hard to fit back in without kinking and if it kinks, prepare for a strong smell of fuel in the cabin and potentially a leaky fuel tank when you fill to the brim.
Edited by SargeRX8
This!
And also the shape of the hole means you end up trying to cut your fingers off every time you turn the black lid.
Nissan only needed to make it 10mm bigger all around! Sheeeeesh!
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
