Selling my 1995 R33 GTST, RB25/30, 500HP, 380KWATW (safe 98 tune)
Fully engineered and registered till SEPT 2013 for NSW
  • Motor built by UNIGROUP ENGINEERING using best parts available
  • Gearbox built and modified by AWARD
  • Nismo twin plate coppermix clutch
  • Nismo dash
  • R33 GTR rear end
  • R33 GTR rims, Hankook RS3 tyres
  • R34 GTR front seats
  • Bonds half cage
  • White Line sway bars
  • Adjustable camber arms
  • Bilstien shocks
  • Best R33 Modified winner at the Shannons Skyline Nationals 2012
  • Wakefield Class B winner at the Shannons Skyline Nationals 2012
  • Import Monster SAU NATS Modified 2WD Class, quickest 800mtr
  • Import Monster SAU NATS Modified 2WD Class, Highest speed 800mtr (245kph)
$18,800 negotiable
Lots of stuff done, you need to have a look.
If you are looking for a car that can lap Wakefield, run a low 11 sec quarter and drive to Queensland for a cruise then this may be what you are after.
Engine specs
Head RB25:
  • Drain backs/vents
  • Drilled out oil returns
  • RB26 cam covers with MINES baffles
  • External oil feed (1mm restrictor)
  • ROSS CAS
Block RB30:
  • JE pistons
  • Eagle rods
  • ARP studs
  • ACL bearings
  • Hi volume race sump
  • TOMEI oil pump
  • EARLS oil pressure regulator
  • ROSS balancer
Bolt ons:
  • Custom steam pipe exhaust manifold
  • TO4Z
  • TIAL gate
  • Greddy copy inlet
  • 600 x 400 x 100 x 3" IC
  • 3" IC pipe
  • QF45 throttle body
  • 4" intake
  • Blitz BOV plumbed in
  • Alloy FENIX radiator
  • LINK ECU
  • Limited to 7500
  • I-shift set at 7200
  • LINK 7 bar map sensor
  • GREDDY EBC
Motor and accessories was all balanced.
Spares that will go with the car when sold if you want them:
  • A pair of R32 GTR rims with Mickey Thompson 255/50 16 ET street drag radials
  • A set of std discs
  • Pair of rear king springs
  • Some boot trims
  • A spare RPM racing harness
  • A fire ext
  • A pair of OMP gloves
  • A RPM balaclava
  • Some new silicon hoses
  • First aid kit
CALL 0467 337 446 TO ORGANISE A TIME TO VIEW THE CAR
WILL NOT DISAPOINT, NO TEST PILOTS OR JOY RIDES PLEASES
Looks like the same car as from here...
http://www.skylinesaustralia.com/forums/topic/418712-r33-gtst-2530-500hp/#entry6725560
Nice C&P on the Start of the advert too...
What's your point? The guy's obviously selling the same car, so wouldn't including the same information be a good idea?
Edited by Shano3000
My kids miss this car, they would always ask me to "crack the gate" when I dropped them of somewhere so their friends would go "oh ah", I do miss it on the odd occasion as well, like on track days, Wednesday nights. cruises, drives up the mountains.....etc. etc.
BTW the rims look good painted.
Good luck with the sale.
  • Like 1
Thanks Mark, enjoying every moment of the car myself,.
I wish I didn't have to sell this toy, but need a four door.
Hopefully I get back into another RB powered machine in the near future
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
