Previous Thread:
http://www.skylinesaustralia.com/forums/topic/392177-wrecking-1995-r33-gtr-midnight-purple-non-v-spec/page-10
..and I still have a ton of parts here!
If it isn't listed below chances are it's there so please PM.
Car is stored outside so I am reluctant to sell glass, doors, boot lid, etc..
Located in Boronia (SE Melbourne) however happy to freight.
Contact via PM.
FOR SALE:
- 215/45R17 87W Toyo Teo Plus Tyres (Brand New - Set of 4) - $400
- GTR Front Pipe - $160
- Front Driveshafts (require driver side inner) - $120 pair
- Original CD Stacker from R33 GTR (with remote & Loom) - $50
- K & N Air Filter Service Kit (1 and a 1/2 kits) - $20
- Speaker Grille's (Hertz, Focal & Response) - $30 the lot
- Rear Reo - $120
- Rear Garnish - $80
- Front Door Trim (Driver) - $120
- Rear 1/4 Door Trims - $80 each
- Rear 1/4 Upper Trims (C-Pillar) - $60 each
- Electric Window Motors - $120 each
- Passanger Electric Window Switch - $50
- Dash - $220
- Centre Console - $120
- Interior Carpet - $120
- Seat Belts - $60 each
- A Pillar Trims - $50 each
- Roof Lining - $120
- Standard upper arms - $160 pair
- Standard uprights - $160 pair
- Front Crossmember - $220
- ABS Unit - $350
- Windscreen Wiper Motor - $80
- Windscreen Wiper Arm Linkages - $80
- Instrument Cluster Surround - $50
- Brake Master Cylinder - $120
SOLD:
Clutch Master Cylinder
Fuel Tank & Pump
Engine & Gearbox
Exhaust
Intercooler & Piping
Airbox
BOV's & Return
PS Pump
A/C Setup
Wheels
Brakes
Brake Air Ducts
Hubs
Struts
Lower & Upper Arms (Front)
Castor Rods
Sway Bars
Rear Driveshafts
Steering Column
Steering Rack
Strut Braces
Tailshaft
Rear Subframe
Underbody Bracing (Rear)
Diff
Atessa Pump & ECU
Relay/Fuse Box
Boot Trims, Plastics, & Carpet
Boot/Fuel Release Cable
Locks & Keys
Spare Tyre
Jack & Mount
Series 3 Xenons
Front Lip
Front Grille
Front Indicators
GTR Wing
Sideskirts
Side Mirrors
Fuel Cap Flap
Bar Skin (Rear)
Bonnet Lining
Guard Lining
Antenna
Seats
Seatbelt (Driver)
Steering Wheel
Instrument Cluster
Sunvisors
Front Door Trim (Passanger)
GTR Coin Slot Cover
Driver A Pillar Trim (Driver Side)
Electric Window Switch (Driver Side)
Floor Mats
Heater Box
Heater Core
Gyro behind Airbag
Airbag Sensor
Triple Gauges
Manual Surround
Head Unit
Cheers - Chris
  • Replies 67
correction to above...
Brake Master Cylinder - $120 is actually meant to read Brake Booster - $120.. must have had a brain fade..
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
Did the front bar sell mate?
Is it actually destroyed or just scrapped and no lip?
Thanks
hi adam,
yes i still have the front bar skin and definitely repairable just depends how keen you are to repair it.
Do u still have the engine bay fuse box?
contents of fuse box there but plastics assembly itself is gone.
cheers,
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
