Hey guys,
I'm trying to build my own oil cooler kit and I need some help with fitting and hoses.
I've bought:
-GREX sandwitch plate with built-in thermostat (-10AN outlets)
-Mocal 19 rows oil cooler core (5/8BSP outlets)
So I'm just wondering what's the best fittings/hoses to use to join both of them up.
I'm thinking of using -10AN braided hoses, so I'll get 2 x -10AN to -10AN hose and 2 x 5/8BSP to -10AN hose? Is that correct?
Also, any recommendations on where I could get them from?
Cheers
https://www.sau.com.au/forums/topic/427723-oil-cooler-fittings/
I used Speedflow fittings and hose (115 teflon / black nylon braid) from motorsport connections in Moorabbin https://www.mscn.com.au
Speedflow seem to be the best fittings I have seen, but check out Proflow as well - I think they are cheaper. Bends etc are not as tight from what I can see but the Speedflow ones are off the planet expensive. A good tip is the straight fittings are much cheaper than any of the bends so if you can get away with a straight its a good thing for the wallet.
Google proflow - lots on ebay and I think you can buy them direct from their website.
Thanks Paul, I've been looking at speedflow and aeroflow, both on ebay. But I can't seem to find any of those fittings for 5/8BSP, as that's the outlet from my Mocal oil cooler... Any recommendations?
Yeah give Motorsport Connections a yell - they haven't failed me yet with being able to adapt to whatever is required. Not sure about ebay but I think Speedflow control the price so generally they retail for same from all dealers.
All the coolers I have dealt with have had AN fittings (JIC) or a metric female boss fitting that you can screw your desired male adapter into. I think you will need an adapter to use the Speedflow stuff on a BSPT but give them a call, tell them what you have to connect and find out your options.
Yeah, my Mocal cooler seems to have a built in male BSP connection..
But will give them a call for sure, as they are close to me too.
Will keep you guys updated :)
Cheers
Mine are all MSCN speedflow! Awesome gear!
^^ +1
I had nothing but issues with Proflow teflon fuel hoses and fittings leaking, TorquesUK has helped me out many times with braided lines for fuel and oil without a problem.
For oil I prefer the black nylon braid rubber cored hoses for oil cooler lines, as it is very flexible compared to the stainless braid. http://www.ebay.co.uk/itm/10-AN10-Nylon-Braided-Stealth-Black-Hose-1m-/170690866285?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bdf7ec6d
here's my Mocal & GReddy GREX setup:
http://www.trak-life.com/diy-r33-skyline-oil-cooler-with-thermostat/
I went for a Mocal core with dash fittings rather than BSP (which might cost less, but cost more after converters, etc.)
Had a really really good search for fittings... RARELY anything for the 5/8" male outlet on the cooler...
BUT, I did find 5/8" BSP female to 1/2" BSP male and speedflow fittings for 1/2" BSP female to -10AN hose.
So I'll be converting my 5/8" to 1/2" then use speedflow 1/2" adapter for -10AN nylon braided hose.
Can anyone let me know if this idea is ok?
​I understand that the more joints I have, the more chance of problems occurring......
So you need something like this... http://www.ebay.com.au/itm/AN-10-10AN-Male-1-2-BSP-BSPP-Female-Adapter-Mocal-Setrab-Oil-Cooler-/380572024115?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item589bdc3d33
But with a 5/8 bsp thread tapped into it? They may not exist, you may have to modify one and run a tap through it. I could probably help you if you can't find something local. Or you could run the adapters if you have the room...
Really depends where you mount the core, if you mount it where I have it, between the a/c condenser & FMIC, left from the a/c condensor fan you will not have much room available to fit 2x convertors and 2x dash fittings. Unless you mount it just before the wheel arch where it's also commonly mounted.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
