Hi all,
I am in the process of getting some bonnet dampers in to suit R33/R34 and possibly S13's. If anyone is keen on a set I will place a larger order so I can get the price down.
At the moment it is looking to be around the $70 for a black set and $100 for a carbon set.
Will know exactly how much when I place the order, the $$ is tanking which is a bit crappy.
This is just a EOI at the moment, still a couple of weeks away from confirming anything.
Who is keen?
https://www.sau.com.au/forums/topic/428030-eoi-skyline-bonnet-dampers/
I'd be keen for a set. Been meaning to getting some just never got around to it. I assume they're universal? So no specific brackets or anything..?
Im interested. I have a 180sx (240sx kit because its american) on mine and the struts were to strong and slightly to long so I couldnt use them. The ones I do have are too weak.
Got any pics of the kit you have in mind?
Ill ask about 32's as well.
These dampers are only for GTST/GTT, the bonnets are around the 17kg mark and the dampers are made for this weight.
If I get enough interest Ill see about dampers for GTR's. Can anyone tell me the weight of a GTR bonnet?
I want to order some sample sets for different models so ideally I would like some willing people to test fit these.
ER34
R32 GTST
S13 Silvia
S14 Silvia
I am assured these work with these model/weight bonnets.
If you have the above model and would be keen on a set shoot me a PM. A small deposit will be required.
Here is a pic of what to expect:
First in with PM and deposit gets it :)
I'd like to have the cars at my place so I can check install and operation.
Tried to PM before but got an error that you couldn't receive messages.
Matts probably closer if it is for a test fit! So try it out and let me know how you go :)
Either way if you can make them work i am keen! Would be pretty handy considering the amount of time i spend under the bonnet lolz
Agreed. More room with a higher bonnet plus no obstruction when working. WIN WIN!
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
