ID have released a all new injector the "ID1300", tech info http://www.injectordynamics.com/ID1300.html
Introducing the ID1300
When we let the cat out of the bag at the PRI show in November, we had no idea we would get the kind of response that we did.
Instead of answering questions about when it will be ready, we are hearing from dealers, and individuals who tell us that their build is on hold until they get their hands on them.
Well guys...we are as excited as you are, but we are also unwilling to release an injector until it is good enough that we can call it the best, without reservation, regardless of the application.
What we are willing to do is use this opportunity to tell you a little bit more about it, and how it came to be.
The ID1300 is the result of a technical partnership between Injector Dynamics, and Bosch Motorsport This partnership allows us to start with a clean sheet of paper, to develop an injector with characteristics that will make it perform well in a wide variety of performance applications.
The ID1300 Offers
  • Compatibility with all known fuels.
  • Stable operation over a broad pressure range.
  • Low minimum fuel volume, capable of stoichiometric idle in small displacement engines.
  • Smooth controlled response at low pulse widths, allowing accurate linearization using all OEM methods (Ford, GM, Chrysler, Porsche, Subaru, etc.)
Coming soon to a dealer near you...
cut and pasted from there website
wondering if anyone has any ideas or thoughts about them, I put a set on order yesterday and they will be available in 2-3 weeks
https://www.sau.com.au/forums/topic/428032-id1300/
Interesting, especially given they are short form factor injectors. At low pulse widths they have a noticeable spike in fuel delivery (see linearity deviation curves) but as for how much difference this actually makes.... I'm not sure. It depends on what kind of pulsewidths you're running at idle but it is a different characteristic to their other injectors.
Another excuse to hold off on injector purchases until I hear more about these :unsure:
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6914675
  • 3 weeks later...
Was hunting down injectors and i heard that they tested these injectors with a much thinner viscocity compared to that of the fuel we use. If i can find an article i will post.
even if that is the case who cares. injector dynamics have an excellent reputation.
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6949956
BS....
They're one of the only injector companies that don't use 'test fluid'.
https://www.sau.com.au/forums/topic/428032-id1300/#findComment-6950049
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
