well was driving - gave the car a pedal full in 4th then 2min later in 3rd and then something went not sure was so quick thought something popped off like a line or something - from what i remember was extra air or something - hit neutral and then pulled ovver.
so checked all lines and pipes there ok, few revs fine bov works..
drive off test alittle and the sound is so different like its missing something bov seems quieter..
then i notice no waste gate sound nothing - normally its loud.. as loud as bov like a flutter.. anyway nothing and boost is only hittin 10psi, which is spring level, (tuned to 20psi)
so things are pointing to the waste gate..
its a turbosmart 50mm pro gate and been on the car for approx 1500km max half of that was on 10psi and some working the new clutch in..
what do you think.. i am thinking something has happend to the gate,
has this happened to anyone before? how did you test it/ check?
everything else with the car seems fine running normal spooling ect
https://www.sau.com.au/forums/topic/428110-well-this-didnt-last-long/
It might be sitting partly open, making the car feel sluggish and the turbo not able to build enough energy to hit target boost.
I shouldn't be making conclusive statements at this stage though.. I don't understand some of the symptoms described.
OP your thread title says it didn't last long; when was it put together and by who? If you paid a shop for this setup have you considered taking it back for them to diagnose?
Not that I don't want to help you, but before we teach you how to cook a meal you might want to take your big mac back to old Ron and ask him about the pubic hair you found on the bun. It made your wife cry, after all.
YEAH it was like extra bov feeling = sorry really hard to describe happened quick..
car builds boost fine but only to 10psi which is spring pressure and can no longer here the wastegate releasing..thinking something is happend to the gate gonna pull the gate off and gonna take it to be checked
wastegate was brought through a performance shop.. arrived assembled and ready to go we welded and installed the gate tp the manifold
so went over everything cant find any leaks nothing everything is on and tight... told my tuner he said boost leak... but car boost normal and hit 10spi easy and normally and holds (wg spring is 10psi) which to me says no leak?
like i said i could hear the wastegate open/close of water ever its called my tuner understood.. he said i wouldnt hear it as boost controller is set for 20psi so wont activate till 20 psi is hit?
my other possible theory is the electronic boost controller has failed hence why only hitting wg psi.. but if bc has failed and im hitting wg psi the the wg should be activating?
i will be hooking up a turbosmart boost T at 20 psi and try that see if that makes a difference.. any other thoughts?
You definitely hear gate, even when it is plumbed back. Its just not as loud as a screamer obviously. Also totally confused as to what the op is describing, I think the 'sounds like a bov' thing just confused everyone. Something has happened that has made the car go from 20psi to 10psi, which to me sounds like a leak if the wastegate isn't opening.
OP, have you tried using a leak tester? Or are you just poking your head around the engine bay to find the leak?
pls forget the bov sound lol but you do understand when i say you can hear a wg? i can no longer hear that
just checked all lines make sure none have come off and all pipes are on tight..
if i did have a leak wat would be the chance of only hitting 10psi consistently in each gear?
wg is a turbo smart 50mm pro gate and is plumed back. and can normally hear it easily.
if boost T dont work i will be trying a leak test i am currently researching the smoke test - any other easy test?
what you mean by confused about "Also totally confused as to what the op is describing,"
Edited by Reese69
Well if you have a split in a pipe that is opening up at 10psi then that'd explain it. On my car I found a leak in my intercooler plumbing that started leaking at 11psi. It was only a small leak so it didn't stop me getting to 20, but it certainly made it take longer. I found it using a leak tester I made, seals off the intake system and then by pumping compressed air into it you can easily hear where any leaks are coming from. Much cheaper than a smoke test, and pretty much fool proof.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
