A few last minute updates before the hillclimb next weekend.
I sandblasted the red top rocker covers over at the machine shop.
In exchange for some beers, they welded on the dash fittings.
I have since dropped off the covers to the powder coaters, to be sprayed wrinkle/crinkle red. They had to order in the paint and so wont be ready until mid week. I'm undecided as to whether to fit them before the hillclimb or wait until afterwards. I'll see how I go time wise.
I fitted some stickers to meet the Sup Regs.
And also fitted the Topstage bonnet.
It's so light, you could throw it like a frisbie. After a bit of stuffing around and fitting a much softer expansion spring, I was able to retain the standard latch assembly. Some better pics in natural light.
Lastly I had a play with the new GoPro and coppied #@RBN1's video idea.
Edited by White GTS-T
So I bit the bullet and decided to pull the old rocker covers off and fit the catch cans in preparation of the freshly painted items being finished today.
I arrived at the powder coaters just as the covers were coming out of the oven, and the painter was looking quite concerned. As it turns out, he thinks that the rep sent them the wrong paint. Instead of a wrinkle/crinkle finish it's what they call a textured finish.
It's a bit hard to tell from the pics but..
Posted Image
Posted Image
Posted Image
He told me to take my money back and to bring the covers back after the hillclimb and they'll redo them. But I don't know if i'll bother...Thoughts?
Cheers. Hopefully i'll get to fit them today and see what they look like fitted up.
#@byebye I haven't had a chance to use them as much as i'd like, but they proved invaluable when setting up the ikeya gear, having to remove the arms to make incremental changes. But I did put it on a brand new high end alignment machine thereafter and it was spot on.
The powder coater rang first thing this morning, he said that they supplier may have got the ratio of the additives wrong. They've ordered more paint and said to bring them back in.
In the interim, I fitted the baffles back to the red top covers.
Posted Image
Interestingly, the red top baffles were bolted in, while the silver top baffles are rivited.
Although they're a missmatch for the turbo setup, the Tomei cams still look as good as the day I installed them.
Posted Image
The Hi-Octane catch can was modified to take the AN fittings.
Posted Image
Posted Image
And the custom can that fits around the strut tower.
Posted Image
Posted Image
I dummied up and then made the hoses.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
I was worried about the shorter hose at the rear being too stiff and consequently not providing enough flex for when the motor torques. I came up with a bandaide solution by soft mounting the catch can with rubber mounts. But I think i'll have to revisit it after the weekend.
The only drawback is that since blocking the pcv valve, the power fc is hunting quite badly at idle. I plan to take the blanking plug off and to fit a small breather filter to it until I can get it retuned.
  • Like 1
Not pictured, is the same air filter mounted to the front catch can. It fits up underneath.
I've also ordered some proper earls hose clamps but they have yet to arrive, so the zipties will have to suffice in the meantime.
The last thing to do is make up a bracket for the igniter, but ill get to that later. Off to the hillclimb tomorrow.
So the Hillclimb has been run and suprisingly won.
To be honest, I had NFI what I was doing, so I'm not too sure how that came about.
I turned up for the optional Friday night Scrutiny, and I was blown away by the level and varity of cars entered. From historics to purpose built Hillclimb machines and everything in between.
After passing scrutiny, I headed back to the Motel and didn't sleep a wink. Saturday morning, I was one of the first to arrive and unload the car.
I was alocated to group 1, which included a standard BA falcon with 300k that a couple of guys had entered just for fun, up to serious time attack weapons like the carbon clad WRX 22B.
I approached the start line for the feeler/practice run and I couldn't stop hyperventilating.
I was unfamiliar with the course layout, but after the first few corners the adrenalin kicked in and calmed the nerves. My first run was a 1:02
I got a few "The Stig" comments throughout the weekend, which was a laugh.
Everyone at the event was really nice and very genuine. There were some real characters there and they kept a smile on my face all weekend. I felt very welcomed for a first timer and I even made a few friends along the way.
Over the course of the weekend my times started to slowly drop as I became more confident. Some photos of it in action.
1457646_370303426447811_977472025_n_zpsa
1457566_369824179829069_282402904_n_zps3
1456144_370305973114223_1314902852_n_zps
1452380_370305966447557_655095754_n_zps2
1452144_370304683114352_785823001_n_zps1
1185171_370305986447555_1169725752_n_zps
Unfortunately the day was cut short on the Sunday after a someone had a big crash and destroyed the armco, they were okay but the armco was left worse for wear.
But somehow I still managed to get my times down enough for the win.
Screenshot_2013-12-02-10-24-33_zps558afb
Although I'm still not sure I was alocated to the correct class.
Some GoPro footage. Enjoy.
Cheers man. I think I did okay considering the car setup and tyres I was running. After talking to the guys there, most of which are running semi slicks, they say that semi slicks are worth at least a second or two. I'd love to have another crack with some better rubber and try to dip in to the 40's.
^Thanks. Who knows, maybe if the second day wasn't cut short I might have edged in to the 40's. My times were getting progressively quicker, with the exception of the last run, where I locked up the fronts heading in to the chicane and then miss-shifted trying to make up time.
But the tyres were the limiting factor, as you can see by the 'hairy' moment, at the end of the second video...that and the 3rd gear synchros ^_^
  • 2 months later...
So a snap decision, I decided to enter Winton's Summer Drift Matsuri, that's in three weeks time. It's been 3+ years since my last drift day, so I hope I don't embarrass myself too much, trying to remember how to drift. In lieu of this, this care package arrived, courtesy of Jesse Streeter.
Watch this space.
  • Like 1
Cheers. I was running R33 LCA's and fixed Cusco Upper arms, that are 10mm shorter for -3 degrees camber (This worked really well). But I have since installed the Ikeya Formula LCA's and extended them further, for extra clearance for the wider wheels. However, the new setup has yet to be tested in terms of sliding the car, so I'm a bit apprehensive as to whether it's all going to work together the way I'm hoping it will, or moreover, like it used to.
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
