Set of Brembo R33 GTR brake calipers, lines and pads(front decent, rear pretty low) for sale due to selling the car they were going to go on.
Last owner said he had them tested and they had no problems. Paint isn't great though
$1000 for the set.
PM me for contact number, located Gold Coast.
Thanks
https://www.sau.com.au/forums/topic/428228-r33-gtr-brembos/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
