Will keep the stock bonnet prop in situ (JIC) but nice to use the struts and not have it in the way.
Would hate to have the aluminium bonnet flexed over or slammed shut due to sudden gusty winds.
Do you think that these would be suitable for a carbon bonnet?
I would hate to keep flexing the bonnet due to the force applied by the dampeners while opening and closing.
I'm thinking similar thoughts to R32GOJIRA.
I own a 33 GTST, but am wanting to put a GTR bonnet on it.
Will the weight difference between steel and aluminium bonnet be an issue?
I'd also have to swap the bonnet hinges from GTST to GTR too, will these brackets fit either?
The 32 dampers are weak enough for carbon bonnets.
The 33 dampers are a bit firmer so would need to do a test on them to be sure it would be ok for carbon.
Im sure if you got them your cf bonnet and they were too strong you could sell them onto someone else...
Im going to them to my fg bonnet and see how they go
Installed on my ER34 today, pics here: http://www.flickr.com/photos/82729085@N08/sets/72157634632200282/
Very happy with them, bolted up in a couple of minutes. The struts feel quite strong, don't think the bonnet would fall down even in a strong breeze.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
