you should get a puppy
puppies are awesome and they get more awesome as they age
I'm not home enough to give a puppy the attention it deserves. I think it's cruel to have an animal if you don't have the time to look after it.
i brought mine to work a couple times. Now that the fence is fixed she stays at home.
However I run her in the morning and the gf walks her in the afternoon. helps me get some cardio which is a win
Mmm yes and no, she's clearly matured (2.5yrs now) but she still has that playful puppy side.
She also likes to do things in "boxer" time.
Mia sit! - keep sniffing for another 7 seconds while walking forward then slowly sit down.
Mia come! - keep sniffing for another 7 seconds while wandering aimlessly then start slowly heading toward you.
We also had issues with her eating plants which the last Boxer didn't do, but she's smart and the electric collar and wire in the ground type system worked perfectly and cured her of that in about 2 weeks.
I have a remote version of that now for when we're out walking which has helped her immensely in her response times to commands. I only use the beep setting though as she got used to the old collar that would beep if she was getting too close to the garden, so now a beep is all that's needed to snap her out of whatever trance she's in and pay attention.
Thank you cheap korean electronics.
This isn't a dog thread :)
are you sure?
It can be anything we want it to be!
We do want we want.
this
please pm details of this
Edited by -FIGJAM-
04/11/13
Squat
35kg x 10
40kg x 10
45kg x 10
50kg x 5
50kg x 5
40kg x 10
40kg x 10
40kg x 10
40kg x 10
Pause Squat
35kg x 10
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 6
65kg x 3
Shoulder Press
15kg x 10
15kg x 10
15kg x 10
20kg x 10
20kg x 10
25kg x 3
25kg x 3
25kg x 3
Seated Row
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 6
55kg x 4
Ab Crunches
120
45min boxing @531 calories
Still having major problems with squat and I've had a week off so I'm not tired. I have no idea why the knee is bending in but was very bad today,so will just continue to do 40kg for reps. I'm upset because it feels like I won't make progress this way as 40kg isn't heavy for me but any heavier and the knee bends in.
Edited by L33SH
Might also include food consumption on training days for any feedback.
04/11/13
Breakfast - 1/2 cup oats with chia seeds and cinammon and a banana and apple smoothie
Hour after breakfast - coffee
Recess - banana
Lunch - buckwheat, puffed rice, sunflower seeds, almonds, pumpkin seeds, chia seeds and flaxseeds mix with natural Greek yoghurt
Before training - BN whey protein shake with creatine, taurine and beta alanine
After training - BN whey protein shake with a table spoon of organic peanut butter and coconut spread
Dinner - pasta
2L of water throughout day / night
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
