Birds this is degenerating.
In my defence. I have urged Leesh to seek a physio in both cases as primary. The advice is around providing Leesh with pain relief and comfort before she is able to get diagnosis and professional treatment. I am correct on the root cause of the issue but, being right isn't worth anything to me in this case. I only wish to help Leesh recover and prevent her from getting hurt. I will defer to the professional in every case , I am actually very pleased to be completely wrong if it means Leesh has a healthier back and shoulders.
If my input isn't appreciated and as you say is seen as ineffective and wrong, then I should take that as a cue to butt out. Which I now will. I don't want to cause un-necessary conflict and I mean no offence to you Birds, which it seems I have caused and do apologise for.
Just to get us on track again, here's a comparison of the weights Leesh started with at the beginning of this build thread (~3 months ago) versus some of her best weights in recent weeks. Despite injuries and setbacks (like not being able to perform deadlifts for 2 of those months), I think she has done fairly well for herself.
12/07/13 (59kg bw) vs 30/10/13 (57kg bw)
Deadlifts
40kg x 10
50kg x 10
50kg x 10
60kg x 10
60kg x 3
60kg x 10
70kg x 10
80kg x 10
90kg x 3
100kg x 1
Squats
20kg x 10
30kg x 10
30kg x 10
35kg x 10
40kg x 10
42.5kg x 10
45kg x 3 (failed on 4th)
35kg x 10
40kg x 10
45kg x 10
50kg x 5
50kg x 5
55kg x 5
60kg x 2
Flat Bench
25kg x10
30kg x10
30kg x10
35kg x 10
40kg x 1
25kg x 10
30kg x 10
35kg x 8
40kg x 4
45kg x 2
47.5kg x 1
Close Grip Lat Pulldown
30kg x 10
30kg x 10
40kg x 10
40kg x 10
50kg x 10
50kg x 10
55kg x 5
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 6
65kg x 3
Seated Row
25kg x 10
25kg x 10
30kg x 10
35kg x 10
40kg x 8
40kg x 8
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 5
Standing Shoulder Press
15kg x 10
15kg x 10
15kg x 10
15kg x 10
20kg x 7
20kg x 6
15kg x 10
15kg x 10
15kg x 10
20kg x 10
20kg x 8
25kg x 5
Bicep Curls
10kg x 10
10kg x 10
10kg x 10
10kg x 10
15kg x 10
15kg x 10
15kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 5
20kg x 4
20kg x 4
Captains Chair Knee Raises
10
10
10
10
10
30
25
20
20
25
12/08/13
Flat Bench
25kg x 10
30kg x 10
35kg x 8
40kg x 4
45kg x 2
47.5kg x 1
Squats
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 1
30kg x 10
40kg x 10
50kg x 10
55kg x 10
60kg x 5
60kg x 4
60kg x 4
65kg x 1
Leg Press
60kg x 10
70kg x 10
80kg x 10
90kg x 10
100kg x 10
110kg x 10
115kg x 5
Incline Press
20kg x 10
20kg x 10
25kg x 10
clicking in shoulder - stopped
Tricep Pushdown (double pulley)
25kg x 10
30kg x 10
35kg x 10
37.5kg x 10
40kg x 10
became painful - stopped
Captains Chair Leg Raises
20
20
20
20
20
Knee Raises
20
12th August was 47.5kg bench press. I havent been close to that in months.
Dont know where you've got 30th October from
12th August is not recent weeks
but yes there are gains there because you're a good trainer
You're looking at a single exercise in the whole list. Every other PB has been completed in the last 2-3 weeks.
No, there are gains there because of you. I'm not lifting the weights, only guiding you in the limited capacity that I can. But your lack of confidence in yourself and inability to acknowledge such progress will have you on a fast downward slope in times like this where you need them most to pull you out of negativity.
I'm sorry, I know I've been really negative about gym and I've frustrated you. I will change my attitude and be more positive and accepting of my progress
Update for those interested.
Physio is very concerned. Thorasic spine mainly T6, T7, T8 but also intervertebral joints are causing issues, which I didn't have last time. Also my right side is playing up but nowhere near as painful as left. (Left is injured side from last time)
Rib pain is referred pain mainly from T7 and T8.
Physio remarked she has never worked on someone so stiff before. Next week I need to take Nurofen before going because the facet joints are so stiff; it's very painful (and I'm not a wuss) and she's not working me hard enough to loosen things up very much.
Trying to work out why thorasic is damaged is her priority at the moment. Lumbar spine is very flexible so it's concerning that thorasic is so stiff/painful. My left rotation is basically half of what it should be.
She wants to me to take up my weights again from Monday and wants to see if I'm more/less stiff next week.
She's trying to work out if weights are hindering the problem; I've never been to a physio before weight training and I've been exercising for a long time. I don't want to give up weights but I don't want to go down the surgery path just yet either.
Edited by L33SH
Don't really have a choice as I can't lift my left arm above my head
thats nasty. Ice packs around the rotator & spine (bag of frozen peas in tea towel) for 30 min a time. As often as you can cope with. Just before bed especially. It doesn't feel nice but, will help inflamation. Or whatever the physio has reccomended.
You will get better.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
