Birds this is degenerating.
In my defence. I have urged Leesh to seek a physio in both cases as primary. The advice is around providing Leesh with pain relief and comfort before she is able to get diagnosis and professional treatment. I am correct on the root cause of the issue but, being right isn't worth anything to me in this case. I only wish to help Leesh recover and prevent her from getting hurt. I will defer to the professional in every case , I am actually very pleased to be completely wrong if it means Leesh has a healthier back and shoulders.
If my input isn't appreciated and as you say is seen as ineffective and wrong, then I should take that as a cue to butt out. Which I now will. I don't want to cause un-necessary conflict and I mean no offence to you Birds, which it seems I have caused and do apologise for.
Just to get us on track again, here's a comparison of the weights Leesh started with at the beginning of this build thread (~3 months ago) versus some of her best weights in recent weeks. Despite injuries and setbacks (like not being able to perform deadlifts for 2 of those months), I think she has done fairly well for herself.
12/07/13 (59kg bw) vs 30/10/13 (57kg bw)
Deadlifts
40kg x 10
50kg x 10
50kg x 10
60kg x 10
60kg x 3
60kg x 10
70kg x 10
80kg x 10
90kg x 3
100kg x 1
Squats
20kg x 10
30kg x 10
30kg x 10
35kg x 10
40kg x 10
42.5kg x 10
45kg x 3 (failed on 4th)
35kg x 10
40kg x 10
45kg x 10
50kg x 5
50kg x 5
55kg x 5
60kg x 2
Flat Bench
25kg x10
30kg x10
30kg x10
35kg x 10
40kg x 1
25kg x 10
30kg x 10
35kg x 8
40kg x 4
45kg x 2
47.5kg x 1
Close Grip Lat Pulldown
30kg x 10
30kg x 10
40kg x 10
40kg x 10
50kg x 10
50kg x 10
55kg x 5
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 6
65kg x 3
Seated Row
25kg x 10
25kg x 10
30kg x 10
35kg x 10
40kg x 8
40kg x 8
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 5
Standing Shoulder Press
15kg x 10
15kg x 10
15kg x 10
15kg x 10
20kg x 7
20kg x 6
15kg x 10
15kg x 10
15kg x 10
20kg x 10
20kg x 8
25kg x 5
Bicep Curls
10kg x 10
10kg x 10
10kg x 10
10kg x 10
15kg x 10
15kg x 10
15kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 5
20kg x 4
20kg x 4
Captains Chair Knee Raises
10
10
10
10
10
30
25
20
20
25
12/08/13
Flat Bench
25kg x 10
30kg x 10
35kg x 8
40kg x 4
45kg x 2
47.5kg x 1
Squats
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 1
30kg x 10
40kg x 10
50kg x 10
55kg x 10
60kg x 5
60kg x 4
60kg x 4
65kg x 1
Leg Press
60kg x 10
70kg x 10
80kg x 10
90kg x 10
100kg x 10
110kg x 10
115kg x 5
Incline Press
20kg x 10
20kg x 10
25kg x 10
clicking in shoulder - stopped
Tricep Pushdown (double pulley)
25kg x 10
30kg x 10
35kg x 10
37.5kg x 10
40kg x 10
became painful - stopped
Captains Chair Leg Raises
20
20
20
20
20
Knee Raises
20
12th August was 47.5kg bench press. I havent been close to that in months.
Dont know where you've got 30th October from
12th August is not recent weeks
but yes there are gains there because you're a good trainer
You're looking at a single exercise in the whole list. Every other PB has been completed in the last 2-3 weeks.
No, there are gains there because of you. I'm not lifting the weights, only guiding you in the limited capacity that I can. But your lack of confidence in yourself and inability to acknowledge such progress will have you on a fast downward slope in times like this where you need them most to pull you out of negativity.
I'm sorry, I know I've been really negative about gym and I've frustrated you. I will change my attitude and be more positive and accepting of my progress
Update for those interested.
Physio is very concerned. Thorasic spine mainly T6, T7, T8 but also intervertebral joints are causing issues, which I didn't have last time. Also my right side is playing up but nowhere near as painful as left. (Left is injured side from last time)
Rib pain is referred pain mainly from T7 and T8.
Physio remarked she has never worked on someone so stiff before. Next week I need to take Nurofen before going because the facet joints are so stiff; it's very painful (and I'm not a wuss) and she's not working me hard enough to loosen things up very much.
Trying to work out why thorasic is damaged is her priority at the moment. Lumbar spine is very flexible so it's concerning that thorasic is so stiff/painful. My left rotation is basically half of what it should be.
She wants to me to take up my weights again from Monday and wants to see if I'm more/less stiff next week.
She's trying to work out if weights are hindering the problem; I've never been to a physio before weight training and I've been exercising for a long time. I don't want to give up weights but I don't want to go down the surgery path just yet either.
Edited by L33SH
Don't really have a choice as I can't lift my left arm above my head
thats nasty. Ice packs around the rotator & spine (bag of frozen peas in tea towel) for 30 min a time. As often as you can cope with. Just before bed especially. It doesn't feel nice but, will help inflamation. Or whatever the physio has reccomended.
You will get better.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
