Birds this is degenerating.
In my defence. I have urged Leesh to seek a physio in both cases as primary. The advice is around providing Leesh with pain relief and comfort before she is able to get diagnosis and professional treatment. I am correct on the root cause of the issue but, being right isn't worth anything to me in this case. I only wish to help Leesh recover and prevent her from getting hurt. I will defer to the professional in every case , I am actually very pleased to be completely wrong if it means Leesh has a healthier back and shoulders.
If my input isn't appreciated and as you say is seen as ineffective and wrong, then I should take that as a cue to butt out. Which I now will. I don't want to cause un-necessary conflict and I mean no offence to you Birds, which it seems I have caused and do apologise for.
Just to get us on track again, here's a comparison of the weights Leesh started with at the beginning of this build thread (~3 months ago) versus some of her best weights in recent weeks. Despite injuries and setbacks (like not being able to perform deadlifts for 2 of those months), I think she has done fairly well for herself.
12/07/13 (59kg bw) vs 30/10/13 (57kg bw)
Deadlifts
40kg x 10
50kg x 10
50kg x 10
60kg x 10
60kg x 3
60kg x 10
70kg x 10
80kg x 10
90kg x 3
100kg x 1
Squats
20kg x 10
30kg x 10
30kg x 10
35kg x 10
40kg x 10
42.5kg x 10
45kg x 3 (failed on 4th)
35kg x 10
40kg x 10
45kg x 10
50kg x 5
50kg x 5
55kg x 5
60kg x 2
Flat Bench
25kg x10
30kg x10
30kg x10
35kg x 10
40kg x 1
25kg x 10
30kg x 10
35kg x 8
40kg x 4
45kg x 2
47.5kg x 1
Close Grip Lat Pulldown
30kg x 10
30kg x 10
40kg x 10
40kg x 10
50kg x 10
50kg x 10
55kg x 5
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 6
65kg x 3
Seated Row
25kg x 10
25kg x 10
30kg x 10
35kg x 10
40kg x 8
40kg x 8
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 5
Standing Shoulder Press
15kg x 10
15kg x 10
15kg x 10
15kg x 10
20kg x 7
20kg x 6
15kg x 10
15kg x 10
15kg x 10
20kg x 10
20kg x 8
25kg x 5
Bicep Curls
10kg x 10
10kg x 10
10kg x 10
10kg x 10
15kg x 10
15kg x 10
15kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 5
20kg x 4
20kg x 4
Captains Chair Knee Raises
10
10
10
10
10
30
25
20
20
25
12/08/13
Flat Bench
25kg x 10
30kg x 10
35kg x 8
40kg x 4
45kg x 2
47.5kg x 1
Squats
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 1
30kg x 10
40kg x 10
50kg x 10
55kg x 10
60kg x 5
60kg x 4
60kg x 4
65kg x 1
Leg Press
60kg x 10
70kg x 10
80kg x 10
90kg x 10
100kg x 10
110kg x 10
115kg x 5
Incline Press
20kg x 10
20kg x 10
25kg x 10
clicking in shoulder - stopped
Tricep Pushdown (double pulley)
25kg x 10
30kg x 10
35kg x 10
37.5kg x 10
40kg x 10
became painful - stopped
Captains Chair Leg Raises
20
20
20
20
20
Knee Raises
20
12th August was 47.5kg bench press. I havent been close to that in months.
Dont know where you've got 30th October from
12th August is not recent weeks
but yes there are gains there because you're a good trainer
You're looking at a single exercise in the whole list. Every other PB has been completed in the last 2-3 weeks.
No, there are gains there because of you. I'm not lifting the weights, only guiding you in the limited capacity that I can. But your lack of confidence in yourself and inability to acknowledge such progress will have you on a fast downward slope in times like this where you need them most to pull you out of negativity.
I'm sorry, I know I've been really negative about gym and I've frustrated you. I will change my attitude and be more positive and accepting of my progress
Update for those interested.
Physio is very concerned. Thorasic spine mainly T6, T7, T8 but also intervertebral joints are causing issues, which I didn't have last time. Also my right side is playing up but nowhere near as painful as left. (Left is injured side from last time)
Rib pain is referred pain mainly from T7 and T8.
Physio remarked she has never worked on someone so stiff before. Next week I need to take Nurofen before going because the facet joints are so stiff; it's very painful (and I'm not a wuss) and she's not working me hard enough to loosen things up very much.
Trying to work out why thorasic is damaged is her priority at the moment. Lumbar spine is very flexible so it's concerning that thorasic is so stiff/painful. My left rotation is basically half of what it should be.
She wants to me to take up my weights again from Monday and wants to see if I'm more/less stiff next week.
She's trying to work out if weights are hindering the problem; I've never been to a physio before weight training and I've been exercising for a long time. I don't want to give up weights but I don't want to go down the surgery path just yet either.
Edited by L33SH
Don't really have a choice as I can't lift my left arm above my head
thats nasty. Ice packs around the rotator & spine (bag of frozen peas in tea towel) for 30 min a time. As often as you can cope with. Just before bed especially. It doesn't feel nice but, will help inflamation. Or whatever the physio has reccomended.
You will get better.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
