Bench Press
30kg x 10
40kg x 5
50kg x 2
60kg x 1
60kg x 1
60kg x 1
55kg x 3
50kg x 7
50kg x 7
45kg x 9
40kg x 11
40kg x 7 (close grip)
Deadlift
40kg x 10
60kg x 10
80kg x 5
60kg x 10
40kg x 10
Bicep Curl
20kg x 10
25kg x 9
25kg x 6
20kg x 10
20kg x 10
07/12/15
Squat
20kg x 10
40kg x 5
60kg x 6
70kg x 4
60kg x 10
60kg x 10
60kg x 5
Pulled my groin!
Pull-Up
10
7
7
5
Lat Pulldown
25kg x 10
30kg x 10
35kg x 10
40kg x 5
45kg x 5
50kg x 4
Captain's Chair
50
30
20
20
09/12/15
Bench Press
30kg x 10
40kg x 5
50kg x 2
60kg x 1
60kg x 1
60kg x 1
55kg x 4
50kg x 6
50kg x 4
45kg x 9
40kg x 11
40kg x 8 (close grip)
Bicep Curl
20kg x 10
25kg x 8
25kg x 6
20kg x 10
20kg x 10
15kg x 15
  • Like 1
14/12/15
Bench Press
30kg x 10
40kg x 5
50kg x 2
60kg x 1
60kg x 1
60kg x 1
55kg x 3
50kg x 8
50kg x 6
45kg x 7
40kg x 10
Deadlift
40kg x 10
40kg x 40
Bicep Curl
20kg x 10
25kg x 6
25kg x 5
20kg x 10
20kg x 10
20kg x 10
Hamstring Curl
23kg x 10
23kg x 10
23kg x 10
23kg x 10
So today is D day, the end date I gave myself to transform my body. Since August this year I gradually started cutting out excess/junk food; from October onwards I became more diligent with cutting out alcohol, sugar and fat from my diet, eating less calories by cutting some carbs and increasing protein (no meat!!!) and water intake.
Here are the results. I haven't been perfect as I'm fond of food and a glass a wine very much. I've still enjoyed life...had a beer or a wine now and again, and snuck in a few Lindt balls...
Since October 5th this year, I've lost 4.5kg and a total of 31cm from around my body (stomach, hips, bum and thigh)
Gym sessions have been more difficult for me mentally and physically, and as you can see from my build thread, a decrease in 1RM weights. However; I've still put in 110% into every weight session and also added some hiit cardio!
I can say for the first time I'm proud of my body and how it looks! I'm also proud of myself for staying determined and on track, even with all the things that stood in my path and made things more difficult for me.
Finally, I want to thank my partner and trainer for all his help and support throughout this process. Thank you babe for helping train me, for guiding me with food choices, for pushing me when I needed it and for listening to me and putting up with me complain about my body and how I didn't look like female body builders on steroids. Lastly, thank you for showing me that anything is possible.
Edited by L33SH
  • Like 3
Thanks Leesh
I won't lie...
It's been a hard slog for you and myself!
But worth it in the end :)
You look amazing and you should be proud, as I am of what you've achieved. All natural and all vegetarian makes this body even more amazing. One of the hardest working people in the gym with an intensity rarely seen, and it shows. In spite of us only attending 2-3x a week for a bit over an hour - incredible results.
Glad that you're finally happy with your body :)
  • Like 1
23/12/15
Bench Press
30kg x 10
40kg x 5
50kg x 2
60kg x 1
60kg x 1
60kg x 1
55kg x 3
50kg x 8
50kg x 5
45kg x 9
40kg x 10
Deadlift
40kg x 10
60kg x 10
70kg x 5
Bicep Curl
20kg x 10
25kg x 6
25kg x 6
20kg x 10
20kg x 10
20kg x 10
  • 1 month later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
