I have or had a series 1 rb25det in my 240sx. I have s-tec manifold, borg warner s366 turbo with all the basic supporting mods like intake manifold, AEM EMS and exhaust. I messed the motor up and now I'm searching for a replacement.
The NEO rb25's are getting pretty cheap over here in the states so I am considering converting over. I read on SAU about the neo motor being an all around better foundation than the basic rb25det. Having the solid lifters, rb26 rods and vct makes me want to upgrade this go around. Everything I have will swap right over including the wiring harness. I'm using GM coil packs and the sensors that are required for the AEM like the IAT and MAP.
If you are using the AEM EMS then it is required to swap out the CAS oem disk with the new one that AEM sells. This disk works only with the series 1 CAS. I've been doing tons of research and I can't find anyone that has used the AEM ems with a rb25det series 2 or neo with the black plastic CAS.
So I was thinking if need be I could install the neo RB25det engine and just convert the neo cams with the series 1 cams in order to use the series 1 cas.
-Is this possible??
-Will the AEM EMS work with the NEO CAS?
No cant swap cams. Hydraulic cams in solid lifter valve train = no.
If AEM says the disc will not work with a NEO then it probably wont work.
Change to a crank trigger system or get a CAS disc custom laser cut.
Besides mega squirt what other stand alones are out there that uses the crank trigger system?
If I don't convert my standalone then I guess I have to stay with the series 1 huh??
Err most aftermarket ECUs will happily read a hall effect or VR sensor from a crank trigger.
If the AEM cant then its not a very good ECU.
Link, adaptronic, motec, haltech, megasquirt, autronic, vipec etc etc can read a simple hall effect input. Although I believe the megasquirt prefers a VR sensor.
  • Like 1
Is it possible to use an R32/33 RB26 exhaust cam in a Neo head and and retime it ? Solid cam so to speak with the right CAS drive ?
It may pay to research the base circle diameters of RB26 and RB25 Neo exhaust cams .
Just a thought cheers Adrian .
Edited by discopotato03
Neo cams have higher lift so good to keep. For most cars swapping the CAS type just involves reversing the wiring so I would have thought it possible to make it work even with your aftermarket ecu.
I always knew that the lift and duration are different on all cams but what matters is the gap between the cams and the lifters right?? I've heard about people installing rb26 cams into an rb20 and swapping the s1 cams with the s2 cams.
I know I could do that. I would hope that what ever flaw that the s1 CAS has might be corrected in the NEO cas....
Wouldn't it just be easier to do what you have to do to fit the right CAS onto the cam? You could manufacture an adaptor, or you could weld the end of the cam and remachine it with the right drive. The options are bound to be more plentiful.
There is a local machine shop that has been around for years. I'm sure it would take some sort of computer program and nifty machinery to get this done. Might not be worth it doe.....
A good machinist could do pretty much anything with a lathe, a mill and a pair of verniers.
I wasn't suggesting it as the big solution, just offering up some alternatives. Interfacing one rotating assembly with another rotating assembly is something that car modifiers have been doing since forever. Used to get done with various distributors in order to get electronic ignition onto older engines (as an example).
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
