Hey guys!
I have a few sets of brand new alloys subframe collars for sale and a single brand new (black, very discreet, not YOLO Orange or anything) HICAS lock bar to suit an R32.
Subframe Collars - $60 per set incl. free postage anywhere in Australia
R32 HICAS Lock Bar - $80
If you are keen please contact me via PM and payment can be made in cash, via direct deposit or via Paypal (Paypal would incur an extra 5% to cover costs)
Cheers!
Hank
  • Like 1
got any pictures mate......
Lots of pictures mate, memes, lolcats, softcore pr0n...
OH! Of the parts! I'll get you some ;)
  • 1 month later...
bloody good prices too.
people ask 75 dollars for second hand hicas locks...
mate if i had kept the skyline i would be all over this!
  • 1 month later...
  • 1 month later...
Fitted them on 33s before, no dramas, nice n snug.<br /><br />Not sure on what alloy they're made of though, sorry!
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
