[Wa] Solid Alloy Subframe Collars & R32 Hicas Lock Bar
Hey guys!
I have a few sets of brand new alloys subframe collars for sale and a single brand new (black, very discreet, not YOLO Orange or anything) HICAS lock bar to suit an R32.
Subframe Collars - $60 per set incl. free postage anywhere in Australia
R32 HICAS Lock Bar - $80
If you are keen please contact me via PM and payment can be made in cash, via direct deposit or via Paypal (Paypal would incur an extra 5% to cover costs)
Cheers!
Hank
  • Like 1
  • 1 month later...
  • 1 month later...
  • 1 month later...
 Share
    • So I’m having issues with my power steering. the obvious heavy and light and comes on and off randomly now it’s constantly heavy. I’ve read through forums regarding this issue and what I’ve gather is that it’s referring to hicas deletion. That’s the problem mine didn’t come with hicas.    I’ve rebuilt the steering rack, pump, changed the bent hardline on the rack and taken out the solenoid to clean and loosen up the actuator, applied 12v to get it moving. Roughly checked the loom to see if there’s any damage to the loom and nothing. Now I’m checking the wiring. I’ve tested the wiring to the solenoid and it’s fluctuating between 0.07v to 0.03v. Does anyone know what it’s supposed to be reading? 5v? Anyone one know how this all works? Is there a fuse in between? What else is it connected to? How does it connect to the speed sensor? A resistor fried in the ecu? Please help. It’s been years Thanks in advance
    • that's pretty good condition, those chips are nothing. Get a mobile repairer to sort it out. Nice wheels, I had white 17's on my GT-R once, looked nice.
    • Found a car that has kiki desing wheels on it with diffrent plates that match a 2008 model when clearly it's not white
    • Howdy friends, So this evening I had a need to remove the rear compressor turbo pipe (long story, but I'm replacing it due to a bolt snapping off in the pipe and managing to then snap an extraction bit in the broken bolt, fun times -_-). The rear bolt is a bit of a bastard and very little room to get good leverage. I was able to get a 12 mm socket onto the bolt head, but none of my ratchets were able to fit, so I put together a "stubby" socket wrench to get it out and it worked surprisingly well 🙂. In the past I've "made" tools by cutting down spanners and bending them with a torch etc, but this 3D printed wrench was way less effort. I'll be keeping this one in my "special tool draw" from now on for sure ^_^b https://www.printables.com/model/868973-half-inch-stubby-socket-wrench
    • It looks even better in Person
