u might wana read over the 11 pages again :P
not sure what the big issuel is.... cut the black wire... connect it to a bolt so its grounded...
put foot on accelerator... watch us gauge shows 7psi before you get to 4500rpm.....
I guess it wont work in *everyones* car but from what i've read in the last 11 pages.. looks like its worked on 90% of them...
Would it still work if you splice into the wire like a T.. or do you actually have to cut it ?
try hook it upto a differant bolt ??
I dont know squat about electronics etc, but when i was trying to ground something else on the bolts near the gearstick inside the car, i found a few of them didnt work as a ground very well..
another thing to test.. try disconect the black wire completly and just make sure the boost never goes over 5psi.. (evan at over 4500rpm)
justin i'm not saying it is hard to do. Shit it's only a 2 min job all i'm saying is i can't notice any difference
It works fine for me and I notice quite a difference. Try this. Get on a Freeway in 3rd gear. Get it on full boost at 3000RPM, then flick the switch. Sounds Crazy!!!
Is it possible for this to work if you just bypass the control valve all together.
EG.
It has one pipe going in and one out. If you just take them both off and join together. Wouldnt that to the same affect????
Guys this trick really does work, it makes a hell of a difference.
Just look at the Dyno sheets i was given after my mechanic did it.
It was on the dyno as he was tuning my SAFC but he noticed this mod hadnt been made so he took the liberty of doing it with dyno curves before and after.
Red line is before SAFC (Ignore)
Green line is after SAFC tune
Blue line is after boost controller mod
Gain of 200NM of torque, a shift in the power curve to the left, and boost comes on heaps earlier.
JUST DO IT!
There is another way to do this with exactly the same results. The only difference being that it is not visable inside the engine bay, or if wanting to use a switch can be done from inside the cabin. ( no running wires through the firewall)
Items required
wire ( different colors prefered)
Spade conectors
12 v 30amp changeover relay
on/off switch
Tools required
- wire cutters
- wire crimpers
Time taken about 30 min
This involves cutting wores directly from the ecu located in the passenger kickpanle. if you are not able to, or are not sure of which wire to cut, DONT do this!
1 - Remove passenger kickpanel
2 - on ECU locate plug second from bottom ( while it is still mounted in car)
3 - locate light green wire coming from this plug.
4 - cut wire
5 - install relay
Wiring for relay is:
30 - to green wire car side
87a - to green wire ECU side
87 - to pin 86 on this relay
85 - accessory 12v
86 - switch
6 - install switch
Wiring for on/off switch
pin 1 - to pin 86 of relay
pin 2 - earth
7 - reassemble car
8 - test drive
When the switch is in th ON position you will have high boost mode all the time, when the switch is off, it will run as a standard car ( hi/low boost mode)
Notes:
- Test car was a R33 series 2 - check wiring colors on other models before proceding
- Make sure all electrical connections are insulated
- make sure that all wiring is secured and cannot be damaged by normal operation of the car
Did this Mod.. worked like a charm.... the Car suddenly Came Alive hehe..
Anyways.. can u guys show me a pic of what you did or instruction.. on how u made a switch to turn the mod On and Off.. and another Thing
When i put my foot down, the needle on my Stock boost Gauge goes up to 3/4 or just little bit above that towards the full 1 Bar. So what PSI is my Car running on at the moment.?? only had my car for like a month.
P.S. ( I have HKS Filter and Full 3 Inch Turbo Back wif 4 1/2 inch Tip)
Cheers
SeSaR
Cost effective and easy way to leave the current setup (ECU grounds controller @4.5K) and have an override switch in the system, Is to place a diode inline with the ECU switched ground (0v) and the switch after the diode (see Pic). The diode will let the 0v from the ECU through but will block the 0v from the switch going back into the ECU.
(Warning! Diodes are directional, placed in this circuit the wrong way around will harm nothing but it will mean that the switch when on will send 0v to the ECU and when the switch is off the 4.5K rpm ECU output will not pass through the diode)
Why bother with all this passive relay / regualr relay stuff? A simple 3 way switch(PTT) will do just as good a job?
waiting for someone to shoot me down.....
Ok I did it today, I've attached pics to show my wiring. The car to me feels like it's got more urgency through the rev range now. I've also attached a pic showing where my stock needle goes to, it does this straight away and holds there. Can anyone confirm that this is the right place for the high 7-8psi factory setting as it's been a while since I booted it and could just be mistaking the feeling of power for standard 4-5psi.
Cheers
PICS!
We soldered this and then taped it up.
Then we rubbed some paint off and bolted our earth to the chassis.
Here you can see how it all looks, pretty tidy.
And this is where my needle sits now...
Hope that helps someone, now can anyone confirm that this is the right place for the needle to be sitting.
very neat dan....
dont quote me, but i thought the wire had to be cut, not just tapped into like you've done?
I may be wrong, but thats how I thought it HAD to be done to work...
and your gauge is sitting on maximum vac....so that really has nothing to do with the high boost mod as far as i know
but at stock high boost the needle should be on or just above the middle slash on the boost side of the gauge....
LoL, I posted the wrong pic, here's the right one!
The red line shows where it sits.
Someone please confirm if it needs to be cut completely or tapped into is fine and if my neddle position is fine. shown by the RED LINE.
Cheers
if thats where its sitting on full boost BELOW 4500RPM, id say its working fine....thats about where mine sits....
my car showed 8.4-8.5 the whole way on the dyno run...and my aftermarket gauge shows 8psi....and my stock needle is about where urs is in that pic :pwned:
Awesome, feels like it's got more push through the mid range but just wanted to be sure.
I also just put some redline box oil in today too. I'll post about that the appropriate forum =)
Looks like my tap into black wire works too =D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
