Done this a few weeks ago, great little mod, it gets rid of that peaky feeling and gives the car a smoother power curve.it is a bit dangerous in the wet tho hehe
Havnt had any problems so far which is good
Nice mod paulr33
i have a question mite sound like a bit of a tool but anyway.. the 7 on the factory boost gauge is that 7psi because the unit is in mmhg or something like that so how do u convert it to psi?
yep i did this mod like 2 weeks ago and its great! ran a wire through the firewall and attached it to a 2 way switch.. up for hi boost, down for low.. haha it works a treat! i dont use hi boost much any way.
ill post some pics up this week. :( its really really simple. took me umm 10 mins all up.
i just have got around to doing this mod, and works like a charm, very easy, and i can feel the difference for sure, just to help, i have a series 2 1997 r33, it is the black wire. i just used rubber shrink tube over my wires and looks very neat and safe.. thanx for the mod info!
half way on the factory gauge is approximately 7psi
+7 on the gauge is ~14psi
hey is this true?, when the gauge is up to +7 thats 14psi?, damn, mine has always went to the +7 and i do not have a aftermarket boost controller or blled valve?, any one know why this is happening?, i do not know all my mods in the engine, but there is a dump pipe that has one pipe going of the side to the same pipe and both sides going to exhaust?, i did hear a guy say the internal `waste gate was takin out?, but i dunno, havent looked and i cannot see any external wastegates any were? help?
yea thats what i was just thinking, killed my friends wrx, so think im running to high.. hahah damn, thanx for clearing me up about the stock gauge, never knew that at all.. wonder why they just dont make the gauge to 7psi reading as they want you to run that :whistling:
hey dezz thanx 4 that. still shocked that the +7 is 14psi, ive always thought it was 7psi, hehe.. i couldent find any info on the net about the stock gauge and what nissan mean on there stock boost gauge reading
looks like im, boosting a bit to much,, hehe, found this: 700 mm/Hg, which is about 13.5 psi. and 400mm/hg is around 8psi.. cool i get it.. crazy factory gauge can go to 13.5. found some info after 3 hours of looking,,. just incase any one else wants to know and this happends while moding .. thanx dezz!!
Edited by seriesII
just did this little mod, just did a T connection with the black earth wire and grounded it, it worked, its just a little mod for better response low down, its mnot gonna win u guys races, I dont know why you bother with the switches...not worth the hassle, if you want a switch get a in cabin dual stage boost controller.
Gr8 simple mod, cheers!
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
