Asian drivers are really scary - even when we get things right! It's the stereotype that creates that terror :P
Don't worry Dale. I got your fingernail marks out with a heatgun :P
Nah srsly, we just about caught up until the red light punctuated our progress. Taheo was pushing me in the mighty Stag and I wasn't prepared to go over a certain speed being the lead car > just kept a tight line. Enjoyed it despite being wary of the blitz.
it was a good pace there was no way I was going for licence loosing speeds!!!
the Stagea loved the corners, only got caught out by 1 corner when it was incorrectly sign posted and it tightened up greatly, having to hit the brakes mid corner with 2tonne ain't the best thing to do.
those road works with the red light sucked, stood there for quiet a few minutes and no traffic came the other way :/
it was a good pace there was no way I was going for licence loosing speeds!!! the Stagea loved the corners, only got caught out by 1 corner when it was incorrectly sign posted and it tightened up greatly, having to hit the brakes mid corner with 2tonne ain't the best thing to do. those road works with the red light sucked, stood there for quiet a few minutes and no traffic came the other way :/
I know the feeling I had to give the brakes a dab in what sounds like it was the same corner then Shannon pointed out to me that my nav man was still on then I used it as a mini map like on the games and could see the corners coming so usefull
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
