Hey SAU,
what sort of power can you get untill stock internals need to be modified on rb25det? Only reason i'm asking is my setup upopened would get me around 270-300kw on pump fuel, but i'm going e85/flex fuel now and that will give it more power and yeah just want to know.
cheers
https://www.sau.com.au/forums/topic/429022-rb25det-how-safe-are-internals/
Depends which RB25 and what supporting mods etc... Condition of the engine? How it's been treated? Intended use...
Go find the 300kw+ unopened thread which will answer all your questions and allow this Thread to be locked.
how much hard mileage has it done so far?
Mine? About 9000km... Including a close call with a lean out and also overheat (Haltech ECU protect stepped in luckily).
Well here's my setup
Garrett 3076r .82 rear housing
6boost manifold
50mm turbosmart wastegate
Front facing plenum
90mm tb
Sard 850cc injectors
450lph e85 pump -will have surge tank
Link g4 plug and play
Engine done about 120ks easy life, only reason I asked as I was going to use pump fuel but now going flex fuel/e85 and I will gain kw and will have over 300kw on a max of 17psi and wanted opinions on how long internals will last
I had a similar setup and maxed the turbo out... At that stage my engine had done 140000km and has had a rough life... Ran it on 360kw where it was thrashed...
It now has the HTA turbo running 390ish and has 149000km...
It's all in the tune! There is no magic number that will make your engine safe.
How much of a gain did you did from flex fuel? Okay hopefully when it gets tuned it's done right
About 30kw on low boost... We didn't tune pump 98 fuel on high boost though so no full boost comparison. But it's nice and responsive on ethanol, smells good too ;)
350 is about the safe limit, we have a few in the 400's but i would not recommend it.
on a R33 motor right? don't the ringlands let go? I know R34 RB25DET NEOs are built as well as tanks
Hey man to be honest ill tell you a little trick water meth injection if u can do that u can push it further on stock internals
Lolololol..... So you are trying to tell us you can increase the strength of the engine internals? You sir are brilliant!
No I'm saying you can push the internals a little further with water meth injection like less chance of detonation at higher boost.
You can do that with E85 too, its not new and its not a secret!
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
