Hey SAU,
what sort of power can you get untill stock internals need to be modified on rb25det? Only reason i'm asking is my setup upopened would get me around 270-300kw on pump fuel, but i'm going e85/flex fuel now and that will give it more power and yeah just want to know.
cheers
https://www.sau.com.au/forums/topic/429022-rb25det-how-safe-are-internals/
Depends which RB25 and what supporting mods etc... Condition of the engine? How it's been treated? Intended use...
Go find the 300kw+ unopened thread which will answer all your questions and allow this Thread to be locked.
how much hard mileage has it done so far?
Mine? About 9000km... Including a close call with a lean out and also overheat (Haltech ECU protect stepped in luckily).
Well here's my setup
Garrett 3076r .82 rear housing
6boost manifold
50mm turbosmart wastegate
Front facing plenum
90mm tb
Sard 850cc injectors
450lph e85 pump -will have surge tank
Link g4 plug and play
Engine done about 120ks easy life, only reason I asked as I was going to use pump fuel but now going flex fuel/e85 and I will gain kw and will have over 300kw on a max of 17psi and wanted opinions on how long internals will last
I had a similar setup and maxed the turbo out... At that stage my engine had done 140000km and has had a rough life... Ran it on 360kw where it was thrashed...
It now has the HTA turbo running 390ish and has 149000km...
It's all in the tune! There is no magic number that will make your engine safe.
How much of a gain did you did from flex fuel? Okay hopefully when it gets tuned it's done right
About 30kw on low boost... We didn't tune pump 98 fuel on high boost though so no full boost comparison. But it's nice and responsive on ethanol, smells good too ;)
350 is about the safe limit, we have a few in the 400's but i would not recommend it.
on a R33 motor right? don't the ringlands let go? I know R34 RB25DET NEOs are built as well as tanks
Hey man to be honest ill tell you a little trick water meth injection if u can do that u can push it further on stock internals
Lolololol..... So you are trying to tell us you can increase the strength of the engine internals? You sir are brilliant!
No I'm saying you can push the internals a little further with water meth injection like less chance of detonation at higher boost.
You can do that with E85 too, its not new and its not a secret!
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
