Hi guys
Fair bit of talk about the ethanol content in the pump fuel available (united, caltex etc).
There are plenty of people that have spent the money on content analysers, but plenty who haven't.
I thought it would be useful for those that don't have the analysers to have a place to come to check recent fuel batch quality.
So, just tell us when you bought the fuel, where and the ethanol content you're seeing. Don't write about fuel you bought last year, just recent examples. I hope for this to be a regularly updated thread.
Cheers
https://www.sau.com.au/forums/topic/429109-pump-e85-current-ethanol-content/
This thread will be pretty useless as Caltex Eflex is pretty consistant at 70-72 with nearly no variation and i believe United is sitting steady at 85.
/thread.
well piggaz has seen 77 up to about 87 at united servo at rozelle. I'm not a tuner, but suspect that if your car is tuned on e85 and your buying e77 fuel (or potentially worse) then you could run into some problems.
agreed...caltex consistent. More of an issue for united.
Maybe the marine grade for boats is different :P
  • Like 1
A friend of mine cracked all 6 pistons recently because of a bad batch of E85.. Apparently the content changes with the weather.. For example if you car was tuned in summer it would have been tuned with a higher ethanol content because in winter they add more pump fuel because the ethanol does not vaporize as easily in the cold..
Just what I have been told I'm not a scientist or anything..
Sounds more like a bad tune or some other form of failure! E85 has not been known to cause any major issues without there being an outside influence of some form!
Like I said.. I have no clue just what I've been told.. I'm not on E85 just yet but with pump fuel going to $1.80/L I think it's time to invest.
I know, its just comments like that from your mate that give people the wrong idea about Ethanol, there are so many cars running it daily and/or running it under extreme conditions with big power output and having no issues, there are some big $ and high HP cars running it with no issues, these are not the sort of builds you would expect people to run the risk of a dodgy fuel on.
Given that we know that once you get the ethanol content up above about 40% you gain pretty much all the cooling and det resistance benefits of 85% ethanol, and given that we know that even the most variable stuff doesn't anywhere near <50%, surely there is room here to debunk the myths?
The other way to look at it is that as the ethanol % falls from some high value (say you tuned at a true E85) down to a low % (say it bottoms out at 60%) then the true amount of fuel is so very very high that the exhaust temps will still be low and the car will in fact struggle to make power. Instead it will make lots of black smoke.
You are more at risk of tuning it at the ragged edge (if you can find it) at E70 and then getting some true E85 into it and running a bit lean. Then you might get into some grief.
This is running a straight E85 tune.. No flex sensor yet.. Might have caused it to lean out also..
I'd have to disagree with that. United are pretty spot on, from what I've seen. Caltex seems to vary just that little bit more than United.
Either way, just pull back the tune a bee's dick. When I was running the PFC/united tune, I ran Caltex in it and had no problems. That includes giving the car a flogging at hill climbs.
Ive been running pump e85 for last 3 years in my drift car and had it tuned for caltex and have switched between united and caltex on same tune and have had no worries engine still going as strong as ever, all comes down to how well its tuned to compensate for the changes.
I've had a consistant reading the whole time!
This was early on in the piece though, a few years ago. My car was off the road for a while there also. Maybe they have picked up their game?
Mine has been over the past 14-15 mths i think! So possibly?
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
