-7s on a 2.7-2.8 would give you the same or better response then the stock turbs on a 2.6 and given a stroker kit comes with a forged crank rods and Pistons, I would suggest the extra for the kit to get the extra CCs is well worth it for the benefits you get from it :thumbsup:
  • Like 1
The part I always find interesting with these "I want better response" threads is no seems to want to do anything that aids in response
The list of things everyone wants to do to while chasing response
Leave comp standard=wrong
Leave capacity standard=wrong
Fit larger duration cams=wrong
Fit larger turbo chargers=wrong
Even things like exhaust sizing has shown a noticeable difference in response and power right thru the rev range
  • Like 2
Ok, so we are realy gona work on the head, clean it up, up the comp, and leave standed cams with addjusterbal gears, going to set the gates up so they open at the last second and control the gate flutter with EBC, and plenty of tune time on cams and mid range, also looking at e85 options,
Lighten flywheel, stanless dumps and front pipe, are the stanless manifolds worth wile? Or port match the factory and head rap?
As Brett said, tickle the stockers. There is no gains to be made here and you won't be ripping them off to replace/fix them when they fail.
Take that money and buy yourself a front diff.
  • 1 month later...
Post to the top!!
I have -7's on an otherwise stock motor, running a HKS EVC 6 - not the colour version.
As with many others, I was under the impression that boost would be very close to stock.
As you can see in the dyno graph, boost builds very slowly (i reach peak boost 17psi at around 4800-5000 rpm)
I'll be going back to the tuners in Jan for cam gears, larger injectors and a retune, but wondering if winding in more actuator pre-load could help.
Will be turning the boost controller off and seeing what boost i reach running off actuator pressure tomorrow. I have no idea if the previous mechanics checked actuator preload before fitting them.....
Anyway, that's my story.. cool story bro
What's your cam timing
-7s will never match stock ceramics for response :(
When you changed turbos did you reset the wastegate setting on the EBC
You can also adjust the gain on the EVC 6 to get it to ramp up faster
Haven't checked mechanical cam timing yet, but will look at that after NYE.
EBC was installed at the same time as the turbos. It was reset and tuned from there.
I have played with the gain (offset), and have found a sweet spot 113% offset. Any more I lose response... However, I shouldn't need to use the offset function tbh.
I turned off the controller this morning, on wastegate pressure, boosted to 9psi. Might add a few mm of preload to the actuators to get closer to 11psi which i think is the rated spring pressure for -7 turbos.
I know that they will be laggier than stock, but they shouldn't be this laggy
Yeah 16psi at 4000rpm seems normal for -7s so there's definitely something going on with your setup. Upping pre-load seems like a reasonable first step in diagnosis (since its free :) ). Just check that their operation is synchronised with a hand pump after the adjustment.
