there is no way they made there way into the head passed the restrictors so what ever they are they started in the head, or where left in the head when being built
there is nothing I can think of that goes in the head that that could be, even a broken spring would be roundish, but check any way
but id say that is your problem, pull pump apart and make sure here is nothing in it and wash all the oil lines
What about the oil pump or rear main oil seal dowels? Are those intact or still there?
Could have been something left in the block before you/RIPS got it and came loose while running......
+1, id also like that car :wub: , good to see its coming back together
like said before the only way it could get into the head is if it started there, the other piece could have easily gone down the back oil drain into the sump, if nothing is out of place in the head then there is the chance it has falling/left in there during the first build
I welded up a tip that fits down on the bucket and fits between the cam lobe and the cam tower. Takes a little bit to get everything setup perfect.
Just got the shed right before all this happened, otherwise i would be under my car port.
Quick question guys, I have tial watercooled wastegates, so i was gonna go ahead and plumb them. Can I use this line pictured? I did the GT mod so and just have this capped off. its at the rear of the engine on the intake side. It would be much easier than teeing into the turbo water supply.
No thats that cooling mod with the swirl tank tapped into the intake manifold. After reading more than i care to read it looks like that would be more of a return port rather than a supply. So I am going to tee into the 6an water supply for the turbo and reduce down to a 4 and daisy chain the waste gates, then weld a bung onto the upper radiator hose neck rather than weld a bung on the radiator, makes one less connection when you have to pull the motor.
  • Like 1
Drove it home today. So much quieter engine now. Triple plate carbonetic is hella quieter than the twin disk too. wooot. Well I am pooped. Not to bad of an install time. 20 mins for the motor, an hour for the trans ( yeah r34 trans in a 240z with fuel lines in the tunnel is a bitch), wiring 20 mins. Turbo stuff, 30 mins. piping 20 mins (yea tight fit for 2 pipes haha), mid pipe and exhaust, 20 mins, 10 trips to the faucet for water 1 liter at a time...30 mins... All in all, 4 beers and a monster.
  • Like 1
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
