7's would be an absolute pig (no disrespect Piggaz!!) to drive.
Fine for a drag queen auto car that you can build boost on the line but useless to drive as a street or track car.
Less comp means you can throw more boost into it but at the sacrifice of off boost driveability.
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6952331
pretty much this.
mine is pretty responsive, even off boost.
which is a good thing, because I have to wait a looooooong time for boost.
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6952383
Errr? I'm asking why so low? I wouldn't want it that low. I wanted 9.3:1 in my own engine.
Edit. Oops, read out of context. Haha!!
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6952455
Sensitive!!!
Continuing Lukes post, E85 is always going to be a challenge if it's your only fuel choice. Flex fuel is always a great option. 98 and taking it easy on cruises, E85 and cane it for track work.
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6952471
Yep, these were comp ratios that were from a time of (all that was available at the pump)low octane ULP and non intercooled motors :-(
Yeah good call and totally correct. Fuel was shite back in 1986! No premium or ultimate back then.
You need to work out what turbos you're running and what is the intended purpose of your car before you choose your comp. If you're running a massive single and focussing on drag racing or a HP dyno hero then go a bit lower comp and pump in huge boost. If you want a driveable street car or track car with good response and minimal lag out of corners then go a higher comp and smaller turbo/turbos.
Do what works for you, not what everyone else has done as we all have our own goals and uses for our cars!
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6953949
just getting some ideas input what they run wit cars , some say low or high comp - work shop says low but I would prefer some info from owners first how it drives ect.
42r 1.01 rear 3L block full race head 260inlet/270ex 10.25 lift powerglide
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6954213
I have gt42 china, 26/30, 256 9.15 lift, 9.0:1, 4" turbo back zorst.
turbo is thrust bearing, so takes a while to kick in.
still driveable due to comp ratio.
6 speed box helps too. (manual)
but, as stated, what use?
track weapon?(guessing with glide).
https://www.sau.com.au/forums/topic/429590-rb2630/#findComment-6954582
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
