not exactly the same as yours but I installed a fmic on mine and everything is fine. After about 4k rpm if you notice a drop in the power or it isnt building as fast as it should - one of the pipes isnt connected/tightened properly
exhaust will only play a role if its way too big or too small other then that its just noise if its all stock
I have a Neo in an R32 with a good FMIC and 3" with good cat and dump. Just running off the wastegate with no boost control (didn't install the R34's solenoid) I could not get more than 6 psi. That's from a 5 psi actuator. Engine is in perfect health, etc etc etc, blah blah.
You shouldn't be getting too much boost (if that's your problem) from just an exhaust and FMIC. You might gain a psi or 2, and that might get you up to nearly 10psi, but the engine and ECU should be perfectly happy there.
I get to much boost goes to near 1bar constantly and tyred everything boost leak tested aftermarket controllers I even ported they wastegate hole for the hell of it but still 1bar even of just the wastegate actuator so it shouldn't be over 10psi should it unless something's wrong hey only thing else I could think of is ecu has a malfunction ?
ECU malfunction cannot cause that much boost.
So, you're telling us that you have completely dismantled the whole turbo system trying to fix this problem? So you know that the wastegate is 100% free to move, not jammed in some way? Do you have a dodgy split dump pipe installed? Anything else that we should know about?
Has a split dump pipe but flap moves freely vac lines anit stuffed changed all of them
3times to make sure standard turbo standard wastegate and tyred another rb25 one to
Wastegate opens when I put the compresser to the vac line and don't loose any pressure
It's like the when the car is standard it boost to 5psi then 7psi
But after the mods does .5 bar to 1bar lol
OK, so next test. Disconnect the wastegate actuator rod from the gate lever arm. Tie the lever arm so that it is jammed 100% open. Take for a drive and report back. Expect it to take an age to come on boost, but if you drive it up hill in 3rd at about 100 and give it a bootfull it should come on.
If you have an air compressor feed some air directly to the wastegate and set your compressor to push 5 7 10 12 psi in increments and just check each level of pressure make sure the wastegate actuator is opening correctly. Unless its internally seizing up it should still open at stock levels. Also I doubt your split dump is helping. I had a split dump for about a week. It was overboosting. When I tested my actuator you could hear the flap hitting the dump on the inside. It looks fine before you bolt it on but I found it was my issue.
Yer drove it without the actuator on at all makes no boost till high rpm then just makes a lil
And my wastegate flap don't touch at all opens fully backwards in the split pipe so anit hitting anything and slowly tested it to
And opens fine That's what I mean I've tyred near everything
You can test wg spring using a large plastic syringe with a vac line attached to you wg actuator with a boost gauge t'd in. That will determine actuator psi.
Then check that you wg flap dosnt foul on you dump.
If its still a problem put a bleed tap on the vac line leading to your bov.
Check out autospeed.com.au for more info on that
By contrast though, mine is fine and always has been.
So another words Mine should be ok on the mods
How about the boost sensor ? If that plays up would it do anything not the solinoid the sensor on the back firewall
No. The boost sensor on the firewall (the ECU's sensor, not the gauge sensor) doesn't act until much higher boost levels. For example, when I was first tuning my boost controller (on this Neo engine) I had a problem with the pressure regulator I was using. It was basically jammed shut. So I had zero boost control. I saw 1.2bar a couple of times before working out what the problem was. In lower gears it would do this happily, with no savage boost cut type things going on. But if I tried it in 4th gear, the boost would shoot up there and there'd be a fairly savage cut. Once I got the regulator working properly I tried it a couple of times at nearly 1 bar and there was no savage cut (although I do get some R&R behaviour evident at high loads, that's a separate issue). The message here is that the boost sensor not only isn't used to set your boost level, it isn't actually used for anything very much at all. I have a suspicion that it might play a part in determining whether to fuel off the fuel map or the VE map, but that's a separate issue again.
I broke my boost sensor (accidentally) off. Never noticed a difference ever. Was trying to figure out why for a long time haha.
shouldnt have to if other r34s can run the same mods and not have a problem should just work dam it grrrrrrrrrr
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
