I got my car tuned today and the tuner had to turn off the O2 sensor cause it had readings all over the place. At idle it had 0 but with a slight tap on the throttle it just jumped to max voltage.
Is this a sign of the O2 sensor being stuffed? I cut out the plug as it was melted and directly wired the O2 sensor is it possible that if I had the wires wrong it would cause these issues? i.e. white wire into black and black into white
https://www.sau.com.au/forums/topic/429623-o2-sensor-help/
There's a sticky thread at the top of this General Maintenance section - have a read!
At idle, it probably doesn't matter if the ecu is running closed or open loop - there probably isn't sufficient gas flow for the sensor to work correctly. It's likely set quite lean, hence reading 0, a blip of the throttle dumps a load of fuel (acceleration enrichment) so the mixture goes rich (O2 = 1).
If your tuner couldn't explain this to you, find a new tuner.
https://www.sau.com.au/forums/topic/429623-o2-sensor-help/#findComment-6953575
It's a nistune so factory ecu. Hmm so it would be normal for it to jump suddenly with just a blip of the throttle? He was saying that it was all over the place while he was tuning and so he has turned it off at current. I will read through it some more always good to learn
https://www.sau.com.au/forums/topic/429623-o2-sensor-help/#findComment-6954222
Im not too confident in your tuner, unless you have misunderstood him.
The o2 feedback has to be switched off when tuning a Nistune board, but then turned back on afterwards.
As the o2 sensor is a narrow band, it can only show when the car is at 14.7:1. When you blip the throttle it would go richer than this, so of course the sensor will show deviation from 14.7:1.
https://www.sau.com.au/forums/topic/429623-o2-sensor-help/#findComment-6954817
Cheers superben. Had a read of the o2 sensor nistune guide seems very simple. I think I may need to call him and try and verify what it was exactly doing wrong.
On a good note without the O2 sensor being used I am getting very good economy
https://www.sau.com.au/forums/topic/429623-o2-sensor-help/#findComment-6955840
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
