After spending the last year or so learnig how to do stuff on computers (like speling) I have got to the stage where non stop anoying crap keeps coming up on my screen causing me to stop typing(2 words per minute) and to continue closing damn advertisement windows and i thought someone elses name on my jocks was bad :D
Get a antivirus program if you don't have it, and also go to http://www.lavasoftusa.com and download Ad-Aware..it'll look for spyware, the little annoying things on your PC that cause all those popups to come up.
Oh, and stop surfing porn sites too :D
Bro if you're using dialup do yourself a favour & ditch Microshite Internet Trawler for Opera.
It's a much faster browser with awesome integrated features like... popup control !! no third party software required. It is genuinely faster, I will never go back to IE.
I use the google toolbar, and they're courteous enough to let you know that you can take part in a statistic gathering exercise. My firewall makes sure the google module (a DLL file) does not send recieve any data of its own, instead only directs IE to go to websites. So far it worked well.
I run Adaware every month or so, usually picks up a few cookies n shit.
Oh an I also used to use this MASSIVE hosts file that mapped all the malicious URL's and ad URLs like adrotator etc to localhost, so none of em ever loaded up. Never tried to use it since migrating to WinXP though.
Some good stuff to have on your machine....
Ad-Ware and spyware:
Ad-Aware 6 - lavasoft as many people have mentioned.
CWshredder - This is good if your browser has been hijacked.
Hijack This - yes it is the name fo the program which gives you a log of some crap you may not want on your machine and alows you to remove it, but you would want to know what you are doing before you go deleting all this so if you don't there are plenty of forums out there where you can post this up and get help.
SpyBot-search and destroy - I like this program :).
I am also using sygate personall firewall Pro at the moment and it seems alright too.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
