Hey guys,
Been watching these forums for the last year or so and have learnt a lot from you guys...
I recently had to take my baby off the road because I blew my turbo and a few valve seals (crankcase breather hose got loose and melted on my exhaust)!
I've rebuilt my turbo at GCG and now looking to do some head work - the question I got for you skyline guru's out there - I've got 2 alternatives that I got quotes for..,
1. Head service (general) + port and polish (inc. replacement of valve train - oversized) priced between $1500 - $1800
OR
2. Head service (general) + extra for any part of the valve train that needs to be replaced + tomei 257 poncams priced between $1000 - $1300.
Which of the 2 options do you guys recommend I choose? (Unfortunately my budget does not allow me to do both)
Note: my current mods are as follows: microtech ecu, blitz boost controller, GCG highflow stage 2 turbo(rated @ 500hp), front mount intercooler, Bosch in tank fuel pump, jecs high flowed injectors, 3" turbo back exhaust, 100 cell high flow cat, pod filter + an atmospheric bov.
Thanking you guys in advance ;)
Edited by Skud1988
https://www.sau.com.au/forums/topic/429798-r33-gts-t-head-rebuild-question/
If you are just putting on a high flow and aiming for 260-300rwkw - Just service the head and put the rest of the money in your pocket.
Cost vs gain, you aren't going to see it. Spend money on brakes/suspension/tyres/clutch/diff or otherwise where you'll get far more bang for buck
  • Like 1
All I did with my head was get it cleaned up (sand blasted), Valve seats done, new valve guides and seals and cleaned the lifters
Added some Poncams and ready to go
If you don't mind answering, what power figures were you getting with that setup?
Engine isnt in the car yet
And that head setup will have little to do with the power figure, Turbo and supporting mods will really do more then basic head re-conditioning. The Cams will help a little but apart from that its all pretty standard
  • 7 months later...
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
